Any V-flex Feedback from users??
As far as I'm concerned, the V-FLEX with the ignition retard and the overboost protection already saved my engine. When I was developing the boost control function, my fat fingers typed the wrong value (Maximum boost). Luckily, I had the overboost set to a reasonable value and it shut it down. Between driving, typing, and trying to monitor the sensors I had no chance to react fast enough on my own.
Imagine you are on the track and your WG gets stuck. If you don't shut it down, it'll take you no time to blow something up. How many people here had a overboost condition, and now you think how lucky you were that you didn't blow things up? Well the next time you may bot be so lucky!
The $125 is for the MAP sensor only. Not for the complete upgrade. If you already have the MAF kit, chip/board and the PiggyBack, the upgrade is $495 (or $620 including the MAP sensor).
Can you describe what happens with the car when overboost protection kicks in incase my experience with overboost is something else going on? For me the car feels like it shuts down for a second, almost like buck or a single stutter.
We now interface with the Zeitronix wideband system, which allows you to set complex alarms (ex. Boost over 10psi AND AFR leaner than 12.5)...
Keep in mind, the software has a limp-home or safe mode (below 2800rpm or low-load). So if the triggering mechanism is incorrectly programmed or failed, you can still drive your car. (ex. by mistake you set overboost to 0psi or to vacuum, you can still drive your car as long as you do not exceed 2800rpm or you are a very light engine load).
I thought there was one set of docs that showed how to do the install and then another set that explained the functionality? Can you resend them to me. I thought you sent out hard coppies for this stuff? Getting over 20k emails a week you tend to lose things pretty easy.
If you examine the MAP installation document, it points you to the section in the VitesseR PiggyBack where you set overboost and rev-limit. "Global Setting===>Switch"
Monkeys Removed by Request
I'm not sure the innovate has any external alarm triggers. Without a trigger (hi or low), we cannot interface to the V-FLEX. As far as MAP sensor, the one we provide must be used for the V-FLEX as we programmed the DME to understand the characteristics of our sensor.
No, it doesn't have an alarm output. Since the Innovate is on the AMP input on the PB, can't the switch in global setting be set for it or is the MAP sensor using that input?
Setting a alarm just on AFR value is useless. You need to set another condition where the AFR can be ruled as good or bad. Ex: 14:1AFR is fine at idle, but no good under boost.. Unless you can join both conditions (AFR & Boost) you get a false alarm. This is why we chose to integrate with the Zeitronix as you can set complex alarms.
I ran the sandhiils open road challenge open road race last year with VR stage3 kit with Vflex and wasted spark. Lots left in this setup. Not yet running E85, but we have it local and will this spring find out first hand.
