Injector Wiring Harness DIY
I have such a bad set of injector wires that being brittle is causing for grounding out, crossover etc
I want to make my own......
Anybody done this themselves? How?
1 Post
I made my own reference and speed sensor wiring harness a few summers ago. I can't imagine doing the injector wiring to be much different.
Here are the links:
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/291967-for-those-who-are-tired-of-wiggling-the-speed-and-reference-connectors.html
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/359468-the-definitive-hot-engine-no-start-thread.html
Lindsey racing also sells a replacement harness:
http://www.lindseyracing.com/LR/Parts/HARNESS.html
Here are the links:
Lindsey makes great products and are great folks to buy from. No doubt I may go that route....but being a die hard DIY guy I wanted to see where folks had bought the bosche type connectors and what gauge wire they used.
I will need to determine where the original point for these wires go....but I will trace.
They are so old and tired and I am fed up with my car not starting
Guys where can I buy the right connectors and which ones are they
I can't reccomend the LR harness enough. The DME/KLR pin # is printed on each wire at intervals along the whole length and it is literally plug and play. It also only takes maybe 30 minutes to install.
I spent quite some time repairing my harness and even bought another DME harness to use as a guide in making a new one, but once you get started you real how much work it is.
David Floyd - long time no see....
T
Monkeys Removed by Request
great advise guys
I love doing things myself but the thought of the DIY cost approx $50 and the chance of doing it worng.....
cant beat the LR price
I bought it today. Hopefully get it quick so I can get running again
thanks for everyones input
