Spec Billet FW - where's the notch?
As my question implies, I'm wondering how you determine what aligns the FW like the notch on the stock FW. The Spec FW has a set screw on the outside edge, would this be considered the "notch"?
I know the Fidanza does NOT have a notch like the OE one that you line up at the bottom of the bellhousing. The only recognizable "notch" is visible through the upper inspection hole by the ref. sensors.
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
Yes I have the spec scalloped FW and I just lined it up with the stock using flywheel bolts marked it and grooved it with an angle grinder before install.
Is yous installed already?
costas
costas
Yep, it's installed, thankfully the shop that did the installation marked the FW. Checked it by locating TDC on #1 piston. So all looks good...piston, FW & cam gear notch all line up as they should.
