The Cone Filter location
#33
Those examples don't apply to this application...unless someone has a 951 doing hundreds of miles per hour. No matter how fast a 951 is going, it is still sucking air in rather than having rammed in.
#34
#35
Otherwise you might as well say it doesn't matter what the ambient temperature is because the turbo is going to heat it up anyways and then the intercooler will cool it back off. Just doesn't work like that.
More pressure before the compressor wheel should cause the turbo to spool quicker at least.
#36
OK looking at the driving light space it would only yield 177cfm @100mph so it's fair to say it's near impossible to make a ram air system to give a noticeable performance gain . But saying increasing vucum in front of the turbo is simply wrong the net affect of this is shifting the demand plot UP on the compressor map with out increasing inlet manifold pressure .
#37
Turbos pull air on one side and push it on the other. No matter how much air you push towards the pull side, it still cannot pull beyond it's maximum efficiency. So, if your goal is to maximize the efficiency at which the turbo can pull air, just open up it's inlet.
#38
I agree with this, but I think the ram air would really just give it more available air as compared to without the positive pressure. So if ever there was a time when the turbo was having to suck harder because the intake tract was restrictive, then positive pressure would help provide more air. Though technically speaking the intake tract before the turbo is never under positive pressure once the turbo is spooled.
#39
Rainman
#40
If you drive a car at highway speeds, the tail end of the vehicle has noticable negative pressure around it. So for example, if a turbo were to draw air from this area it's already behind in its' ability to make positive pressure because right in front of the compressor blades is less than ambient pressure.
Conversly, the front of a car at speeds, has slightly higher than ambient pressure. When the turbo is sucking, as you put it, it will never encounter less than ambient pressure.
Look at the all out turbo drag cars. They've got the compressor inlet totally exposed, somewhere in the front grill.
#41
951RS;
all what you're saying is correct
And yes, it's not like there's huge gains leaps and bounds, especially, if some of us are just placing the air filter somewhere at the front of the car (in the fender, hood sealed area, naca duct, etc)
Real ram air is if you drive the air into a sealed box, which the turbo can draw from, and that the flow area into the box is significantly greater than the area of the turbo inlet.
Also, none of this has anything to do with increasing or decreasing compressor efficiency.
The issue is what pressure ratio is your turbo working at to make the desired boost (the less pressure ratio, the better).
#42
That is totally not the case at all.
Obviously this is the extreme, but drag cars don't move anywhere near fast enough to gain enough ram air to create stalls, so they just create the largest available opening to allow the compressor to get all that it wants. At some point, that is all that is needed, and more becomes less efficient.
#44
I'm pretty sure we're all saying the same thing, but starting from different ends of the same spectrum.
The ones saying how positive pressure would be beneficial are referencing situations when the added psi would increase available air while the ones saying it would provide no improvement are talking about when there is already enough air available without positive pressure.
#45
Surely there is a fluids engineer in here that can back me up. The turbo inlet has a set restriction, caused by its size. Short of an external way to compress the air ahead of it, the air will be at roughly 1ATM (depending on elevation). Adding a high pressure source (aka "Ram Air" by most car guys) won't compress the inlet air, it just moves it around and causes turbulence. The air at the inlet is still going to be at 1 ATM.
If the air is at basically 1 ATM, then you are probably thinking that it doesn't matter, right? Wrong. The air flowing in is subject to laminar flow properties, which is weird science all by itself and does all sorts of things that the layperson wouldn't predict. The best way of thinking about this would be to think of air flowing around an airplane wing. Ever have a plane ride with a lot of turbulence? Same thing applies to a turbo. By adding a high pressure source, it causes disruptions to the flow (called "eddies") that increase the internal viscosity of the air and slows the flow down. Instead of flowing through the turbo in a laminar fashion so that the turbo can compress it, the kinetic energy is expending bouncing around against other air.
Theres a LOT of science that I throw at you, but ram air doesn't work with turbos and fluid dynamics will back me up on this. Pick a low pressure source with the coolest air you can find and your turbo will work as efficiently as possible, as long as the inlet source exceeds the capacity of the turbo inlet, which it will pretty much anywhere in the front end of the car.
Its interesting to note (if you are thermodynamics geek anyway) that the opposite applies to radiators and intercoolers. You want a high pressure source, as the turbulence helps with the heat transfer and mixing.
For the purposes of a 951, I think this is mostly an academic argument anyway.
Regards,
Regards,
