Phase two of my project - turbo swap pictorial
#121
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Thanks for the information! I am hopeful that mine will fit too! I think it will, but not positive. I guess I only need to put in the Nissan alternator and I should be good to go.
#124
Really nice writeup on this job! Funny that I constructed the almost exact shield on the air filter to keep water from dripping down the hood into the air filter. For now it is removeable, in the trunk until it rains. Like what you did on the turbo oil line.
#125
It is the AIR splitter. Been on the car almost 20k miles and survived 3 winters including driving home in two blizzards on my fairly low car. It is being replaced with one by Joe Toth when the car is back on the road in the spring.
If you wanted, you an have my old AIR for cheap, just come and pick it up on Long Island. It is presentable but will need some fiberglass work to be perfect. It is all one piece but has one crack and a bunch of chips on the leading edge. Amazingly enough it help up fine over the winter but not to me accidentally backing up over some wheel chocks I forgot about...
Really glad you guys appreciate these threads, not sure if there will be anymore as the car no longer has the turbo engine anymore. Besides, I think I covered all the big DIY jobs! Maybe a rear suspension one in the future but ill likely pay a shop to do that!
#127
Awesome Doug! Hope it all goes smoothly.
Any plans to make Hershey this year? Would love to see how far the car has come since i saw it at 944Fest a few year ago. Its possible i may make it in my 951, the first time in like 4 years .
BTW, not sure what turbo your coming from but if it was stock you will love the 60-1. 3rd gear pulls @ 17psi were scary
#129
#130
Techno duck, I'm in the middle of this job myself. Those turbo mounting bolts are killing me!!! I will try to wake up the bolts the way that you did again today. I have not stripped either bolt yet. Is there any other advice for waking up those bolts? It feels like they're now one with the turbo. Any help would be very much appreciated. I'm so close, I don't want to mess up and definitely don't want to give up either.
#131
#132
I am out of town until the end of the month, if you can wait until then i can lend you a hand. Where in SD are you?
#133
Oh the turbo allens? Yeah he's right. That's the best way. Get the extensions set up with the proper allen and put it into place on the bolt. Push it up as hard as you can and then bang the **** out of the end of the extension with a hammer. Hit it as hard as you can a few times, then try to turn it. Rinse and repeat. I went through the exact same thing. I recommend beer!
#134
Also... On most turbos, you can spray a little penetrating oil (PB Blaster or whatever) on the top end of those bolts where they poke up through the mount. Gravity then helps get the oil down into the threads. Also, as with any easily stripped bolt, the key it so keep the tool totally straight and fully seated in the bolt head. Loosening the steering rack helps you get a straighter shot as Duck says. Also, I'm a big fan of using over-sized tools (1/2" ratchet or breaker bar for example) because once you start straining on a little wrench to break the bolt free, you are at much greater risk of putting an unintentional angle on the tool, which is the usually the root cause of stripped bolts and bloody knuckles. With a big breaker bar, set straight on with the bolts, you can stay more controlled and straight as you try to break the bolt free.
#135
When I am using the star or allen heads I am pushing as hard on the tool as I am on twisting... That is key to make sure that that tool is seated completely
Along with with Tom and others say regarding the angle by loosening the steering rack to get a better angle
Good luck
