996 TT calipers on a 951, anyone done it?
I upgraded the front calipers on my 996TT, so I have the old ones left and I thought I'd put them on the 951. Anyone else done this?
Are these the 4 or 6 piston calipers? My guess is that Olli will appear on this thread pretty soon.
They are 4 piston, I will check for extra hardware but I don't remember seeing any. You will need new rotors. I have 18" wheels, and I do not know if they will work with anything smaller.
When you get on them you had better be braced as they will flat slow you down in a big hurry. Also being over sized they will not fade as bad after being used a few times.
On the Radar
Front adapters work either 4 or 6 pot calipers.
Use search, this issue have been handeled sooooo many times.
does anyone know how Nascar claipers rate against Porsche big reds .
I have big reds outlaw's and JFZ's i think are now called sierra racing i have 996 gt3 rotors and the big res stuggle for width i can't decide
Adapters only work if you have an early (220 hp) 951.
If you have a 250 hp 951 the easiest alternative is the 993TT brakes that doesn't need any adapters at all.
Doing what Olli has done is great if you want the bling, but also for some real high hp trackcars going up from the BRs is worth it. Cooling is another advantage of the Monoblocks.
Adam, I reckon these are your next project.
