"Ignorant" brake fluid ?
Yes, it's shared on the LHD cars as well. As long as the fluid reservoir in the master cylinder doesn't drop below the line to the clutch slave cylinder, you don't have to bleed it. Even then, if it dropped a little, it's okay as long as the air that gets in the top of that line comes to the top when the reservoir is refilled. My clutch is still great, didn't bleed it.
