zeitronix WB connected to DME/KLR pin??
Old 09-17-2008, 05:08 PM
StefanS
StefanS's Avatar
Default zeitronix WB connected to DME/KLR pin??
Hello,
My car is a Turbo S '88
I want to install my zeitronix.
-Is it right I can get the signal for TPS out of the KLR (pin 22 green/white) and the signal RPM out of DME (pin 21 green/black)? This is what i red somewhere.
- Can someone tell me what function/signal belongs to each pin of KLR and DME.
- Two of the wires must be connected to power and ground. Can I also use the DME pins?
-Another question I have: Is it possible to connect a oil temp.sensor to wb zeitronix? and how.
Thanks,
Stefan
Old 09-17-2008, 11:05 PM
Tom M'Guinn
Tom M'Guinn's Avatar
http://members.rennlist.com/tom86951...nd%20wires.htm
Old 09-17-2008, 11:29 PM
ehall
ehall's Avatar
cool! Thanks Tom.
Old 09-18-2008, 09:59 AM
Spidey944
Spidey944's Avatar
Did you buy the Boost sensor (MAP) too?? It makes logging much easier on the Dyno if you do. Highly reccomend it!! Well worth the extra $125!!!
Old 09-18-2008, 01:44 PM
StefanS
StefanS's Avatar
Tom,
That was the information I already had. I asked because I do not know if there is a difference between the 86 turbo and 88 turbo S DME and KLR. And I want to know all the pin functions. For example the Lambda. Thats also what zeitronix can read.
I have the zeitronix boostsensor. That's an easy install.
thanks
Old 09-18-2008, 03:13 PM
ehall
ehall's Avatar
They have the write up on the zeitronix web site. If you search rennlist, I believe you will find what you seek.
Old 09-18-2008, 11:45 PM
Tom M'Guinn
Originally Posted by StefanS
Tom,
thanks
I see. Pin outs are listed here:
https://rennlist.com/forums/924-931-944-951-968-forum/315413-dme-and-klr-pinouts-w-wire-colors.html
You can log any 0-5vdc signal on the USER line of the zeitronix
Old 09-19-2008, 06:20 PM
StefanS
StefanS's Avatar
Thanks,
That's what I was searching for.
Tom, u used pin 5 for ground but isn't it better to use pin 19? Can I use pin 24 for lambda?
another question:
If I use the userinput of zeitronix for oiltemp. How do I know what temp the oil is because the displayreading for userinpunt is in volts.
Quick Reply: zeitronix WB connected to DME/KLR pin??
