Torsion bar delete/cantilever arm question
Am I correct in assuming that if the torsion bars are removed, that the cantilever arms serve no useful purpose and can be removed from the torsion bar housing?
Hey Jim
cantilever arm??? Only thing I can think of -is you talking about the spring plates (locates the trailing arms to the cross member) and those can't be removed unless you have designed something else to locate the trailing arm
This thing here. I thought it was called the cantilever arm but I could be wrong. Whatever it's called, it seems as though once the torsion bars are removed that it no longer serves a function. I know the Kokeln rear suspension assembly doesn't have anything like this on it, so I am thinking it can be removed from the stock unit during a torsion bar delete?
When you guys pull the torsion bars, are you reinforcing anything or upgrading any of the bushings? All the track cars I maintain have to have the torsion bars per club rules (so my experience with pulling them and the results is nill), but I am thinking of yanking them in my track car since I don't race PCA (obviously going full coilover). I do have a car that we only run 10mm bars in, so I have to believe that without them isn't going to affect it that much...probably want to upgrade to at least some delrin bushings though? I am too lazy to search, sorry.
That PCA rule is dumb. Turn them down, shave the splines, or pull them out... what's the difference?
I have too running without torsion bar with a set of recently installed Intrax RSA from Lindsey Racing. The car is sitting at the right height but I run into problem not able to adjust proper camber or toe. The minimum camber the mechanic could get is -2.5 but with crazy amount of toe, but when he adjust for the correct toe, the camber with go -4.0. Tried to adjust the ride height using the eccentric in the spring plate, the axle only move for a few mm. Is this to do with the removal of the torsion bar?? Or is there something we have missed?? Thanks for your help!!
If you are tracking the car, it makes good sence to look into the Elephant poly bronze springplate bushings. The rubber on the springplates gets old and out of round, and is the only attachment point to the tube, without T-bars, as I recall. I removed mine some years back, from my old 86, and ran with the stock springplates, but I didn't track the car. YMMV
Rennlist Junkie Forever
Bushings: You need to get the torsion bar carrier solidly mounted to the chassis. This is done at two points on each side.
Also, you need to get spring plate bushings (Weltmeister, or Delrin, or Elephant Racing's bushings... anything other than stock) and rear control arm bushings as well .
TonyG
Yes, it is an experience to align the rear end of the 968. We found out it is worn slots and eccentric bolts caused the issue. Now, we need to make up some new eccentric and clean up the slots get it working and allow better range of hight, camber and toe adjustment.
