How do I adjust rear camber?
Hi,
My orange 951 race car has about 6 degrees camber on the rear. How do you adjust it? I have a camber gauge but am just not sure how to go about it.
TIA
TIA
you need to get the car up with the wheels loaded the outer part of the trailing arm bends when you loosen the 2 bolts holding it together this tool
http://cgi.ebay.com/Rear-Suspension-...742.m153.l1262
goes in a hole forward of the 2 bolts as you rotate it the camber and watch it toe will change as you adjust.
you will find better explanations on clarks gararge and pelican parts and i think there may have been talk here a while ago about setting Up string lines for wheel alignments
Isn't 6 degrees in the back kinda wildly more than most have? I didn't think you could get that much adj out of the rear setup?
Does the toe get affected on the rears as much as the fronts when adj camber?
The tool is for adjusting the toe, but the camber and toe are linked so you have to go back and forth to get it close.
http://www.paragon-products.com/product_p/p221.htm
