MAF Question- Car stumbles when given gas
Lazer Beam Shooter
Ok so I wired in the Lindsey MAF last night and everything worked fine.
The car will start and idle perfectly, its just whenever the pedal is pushed, the car will not accelerate smoothly. It will stumble and backfire, as if it were running lean.
Could this be that I have no fuel controller? I just replaced the stock AFM with a MAF and I have autothority chips.
Anyone have a similar experience?
Lazer Beam Shooter
****. I wasnt going to run it until I got the fuel controller, but I got bored and was under the impression that it would work without configuration.
Rock i told you not to mess w/ that until you have all the parts. ITs prob. also directional as i found out on my car- so if its backwards it wont run correctly.
Lazer Beam Shooter
As far as the direction of the MAF meter, the plug should be facing the headlight.
Yeah this is how it is setup right now
