Gauge Time - Pic/Advice Request
Old 03-17-2008, 04:34 PM
Airflite40
Official Rennlist
Borat Impersonator
Airflite40's Avatar
Kevin I love your gauges. Where did you buy them??? The dial AFR gauge is sick.
For all teh guys whose boost gauges only go to 20.......<Nelson Muntz>HA HA!!!!!</Nelson Muntz>
Originally Posted by kevincnc
Cool monkey.
I'm considering moving my AFR and Boost gauges to below the stereo head unit. I like the visibility of having them on the pillar, but it is starting to seem a little ricey for me. Moving them would allow me to put my Oil Temp gauge back in so all three would be there. I don't really need or use the cubby anyway.
I'd like to know opinions on how much harder it is to watch the gauges while driving if they're mounted in the cubby vs on the pillar.
Any comments on one vs. the other?
Old 03-17-2008, 10:04 PM
mj951
mj951's Avatar
VDO - Oil Temp/Boost/Oil Pressure with a Lindsey plate and a lap timer cut into a spare ash tray face plate which I can swap in for track days.
Old 03-17-2008, 11:28 PM
mwc951
mwc951's Avatar
I went with the Lindsey pannel and Sport-Comps.
cb951 had the right idea painting the bezels black.
Mounted the EBC up high where I had easy access and
good view of the boost.
Old 02-06-2009, 06:30 PM
royj
royj's Avatar
My zeitronix in my car:
Old 02-06-2009, 06:36 PM
ehall
ehall's Avatar
Dude, can ya make me one of those?
Old 02-06-2009, 09:00 PM
DanR
DanR's Avatar
have the template if needed
Old 02-08-2009, 05:35 PM
edh
edh's Avatar
I used a Lindsey panel & VDO Vision gauges - about as stock looking as you can get IMO
They aren't as easy to check when they are down there, but I'm only really looking at the temps & pressures when I'm driving down a straight bit of track or road
Old 02-08-2009, 05:58 PM
Spidey944
Spidey944's Avatar
I still like my TechnoDuck inspired 45 degree gauges. Worked out great while I had them.
Old 02-08-2009, 07:57 PM
cb951
cb951's Avatar
Looks nice, but your steering wheel is on the wrong side.
Old 02-08-2009, 09:03 PM
theedge
theedge's Avatar
Best spot IMHO. All you need is a standard Autometer Cup Mounting Kit, and a longer screw to replace the bottom screw that holds the trim on.
Old 02-09-2009, 07:45 AM
edh
edh's Avatar
Maybe the pic is reversed?
Old 02-09-2009, 08:24 AM
tone3721
tone3721's Avatar
I just bought a blitz sbc i-color, with a/f meter/wideband sensor. Its going in the center console just under the stereo as already shown here. With this unit, I was able to delete the uego 02 sensor, mbc, and boost gauge.
Old 02-09-2009, 09:33 AM
Kool
Part of the IN Crowd
Kool's Avatar
Sicne I am going with a stand alone I was thinking I wanted to convert the original boost gauge to run as intended but directly off of vacuum. Do not know how hard that would be. Or if it is possible but I thought it would be interesting to try.
Old 02-09-2009, 12:36 PM
rcatherton
rcatherton's Avatar
Guages
Old 02-09-2009, 09:37 PM
TonyG
Rennlist Junkie Forever
TonyG's Avatar
My old car:
TonyG
Quick Reply: Gauge Time - Pic/Advice Request
