Megasquirt files
Old 02-02-2008, 11:32 PM
fourniem76
fourniem76's Avatar
Default Megasquirt files
Good day everyone... I am in the process of seting up my track 944 with a megasquirt II stand alone system... wondering if anyone has done that already and if you would be interested in sharing the maps...would help me as a starting point at least...
Thx,
Michel.
Old 02-02-2008, 11:49 PM
TRP951
TRP951's Avatar
I beleive his rennlist name is AlexK he is running megasquirt
Old 02-03-2008, 12:11 AM
AlexE
AlexE's Avatar
Shoot me a PM.
Tell me about your setup and I will explain my map to you.
Here is a video of it building boost by blipping the throttle......
http://www.youtube.com/watch?v=eLH1aI3Wo4A
Here is a video of one lap around stratotech here in edmonton
http://www.youtube.com/watch?v=Ra54NfJboKM
Car is on the road daily in the summer and hits the track every weekend.
Running MS2 V3 EDIS
Old 02-03-2008, 06:56 PM
RPHARRIS
RPHARRIS's Avatar
I too run MS-II with EDIS on my 944 turbo. Let me know if you need anything.
Old 02-03-2008, 09:34 PM
Phil R
Phil R's Avatar
I'm considering doing a megasquart system but i'm in process of learning about what i'm getting myself into and what all will need to be changed in terms of sensors and wiring.
so what are the main challenges setting one of these up? what sensors that will need to be changed?
Old 02-03-2008, 10:52 PM
RPHARRIS
RPHARRIS's Avatar
The main challenge for me was definitely figuring out how to mount an appropriate trigger wheel in order to control ignition timing. Setting it up for fuel only took a couple hours. It was very straight forward. Integrating the EDIS was much more difficult but well worth the effort in the end. My car ran identical 1/4 mile times with Autothority stage II chips at 15psi as it did with Megasquirt controlling fuel and igniton at 11psi.
Old 02-03-2008, 11:05 PM
Phil R
Phil R's Avatar
so were you able to use all the stock sensors? were you able to remove the stock computers or did one or both boxes remain in the car?
what did you do about wireing? did you make a all new harness? cut the stock one or simple make an adapter cable to interface with the oem harness. I think I would like this setup just in case I sell the car and want to take the MS with me.
Old 02-04-2008, 12:45 AM
A.Wayne
Formula One Spin Doctor
A.Wayne's Avatar
Have you ran it at 15 psi yet , How much better was it at 15 psi........
Old 02-04-2008, 03:09 AM
RPHARRIS
RPHARRIS's Avatar
I ran it at slightly less than 14psi (I don't actually have a data-log for that run so I'm reluctant to give an exact figure). Heck I'll just give you the exact slip data for the autothority run and the 13-14psi Megasquirt run.
Autothority Stage II at 15psi (best of 5 runs): 14.553 @ 97.640 MPH
1/4 Mile ET: 14.553
1/4 Mile MPH: 97.640
1/8 Mile ET: 9.510
1/8 Mile MPH: 77.220
0-60 Foot ET: 2.501
Temperature F: 80.0
MS-II 10-11psi (verified by datalog) First and Only Run: 14.7xx @ 97.xxx MPH
MS-II 13-14psi (not verified by datalog) (Only run, hit revlimiter in 1st): 14.173 @ 100.600MPH
1/4 Mile ET: 14.173
1/4 Mile MPH: 100.600
1/8 Mile ET: 9.311
1/8 Mile MPH: 79.460
0-60 Foot ET: 2.423
Temperature F: 99.0
I'll leave you to draw your own conclusions, Mr. Wayne
Old 02-04-2008, 04:40 AM
Fishey
Fishey's Avatar
MegaSquirt is alright I think its one of the best bang for the bucks out there but I will stick with Haltech now for more money based on a few things.
Old 02-04-2008, 09:25 AM
A.Wayne
A.Wayne's Avatar
1/4 Mile ET: 14.553
1/8 Mile ET: 9.510
0-60 Foot ET: 2.501
Temperature F: 80.0
1/4 Mile ET: 14.173
1/8 Mile ET: 9.311
0-60 Foot ET: 2.423
Temperature F: 99.0
I was just curious as to what you had at 15 psi , seeing you where running 15 psi before .......
Old 02-04-2008, 05:11 PM
RPHARRIS
RPHARRIS's Avatar
I wanted to run 15psi but I was seeing VERY high duty cycles on on my datalogs so I had to resist until my new injectors came. Last time I made it up to the track I had the 55 injectors and and LR4" exhaust but they canceled the drags that day. Now I have a Super 61 under the hood as well so I'm eagerly awaiting my next trip . I fully expect to be in the 12s before this time next year.
Very true, I really wanted a Tec3 but I had NO money at the time and my DME was on its last legs. I was so broke I actually bought the unassembled board and soldered the whole thing together while watching episodes of House. It got my car up and running again for much less than the cost of a new DME and chipset. I'm about to upgrade to the new SMT version of megasquirt-II.
Old 02-04-2008, 06:29 PM
osbekken
osbekken's Avatar
How would you compare pros and cons with Megasquirt compared to Tec3? Userfriendlyness? Options?
Is the extra cost of Tec3 worth it if u have the money?
Old 02-04-2008, 07:35 PM
RPHARRIS
RPHARRIS's Avatar
I don't have enough experience with the Tec3 to compare it.
What I can say is that the Megasquirt takes a lot of fiddling to get working properly. My impression is the that Tec3 (as a higher priced product) has all of the little bugs ironed out.
One advantage I see for the Megasquirt is the huge cult following. Users are developing cool new features all the time.
Old 02-04-2008, 10:40 PM
RobHeinl
RobHeinl's Avatar
Michel,
I have my 87 944 n/a running great on MS1 Fuel only but preparing for spark (RPHarris, I have questions for ya via private message, if you don't mind). I know that's not much of a help to you but JustinL has his N/A running on Microsquirt successfully. He is also in transition of setting up spark.
I don't know how much my N/A experience will be to you since I used MS1 but fire away if you have any questions. I'd be glad to PrintScreen my 12x12 fuel map for ya or help with Pinouts.
Quick Reply: Megasquirt files
