Anyone running Electromotive Tech 3R successfully?
yes, I check his old posts and he uses a TEC3R BUT, a 2.8ltr is not a 3ltr.
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/205626-project-introduction-with-link-to-pics.html
I think 2.5 ,2.8 or 3.0 or 3.1 3.2 is irrelevant . what is important when setting up is the way the ecu inter phases with the timing pick ups and then the ecu with the operator.
I think it's your panel beater who's holding you back Paul.
erk sorry, couldn't resist. Pot, kettle, black etc...
How is the timing holding you back? I was under the impression you picked up something like 60rwhp? Conditions (CR, boost, fuel octane, etc..) dictate fuel used and ignition. Your base maps must be optimized based on the parameters you have.
Well that is the current theory I've been given. Remember my car has been in the bodyshop since my crash in June and it is still on the base ignition map. Once the repair is finished it will be straight into Indi Jons workshop to have the Wasted Spark fitted and a Vitesse piggyback that is unlocked for timing changes.
The problem we're trying to solve is that any more boost than 15psi under hard track use will bend over the electrodes on the spark plug in cyl #4
Paul, I understand. The cause of the electrode issue must be determined. As I mentioned before. 15psi is the max on pump gas! If you want to run more, a retune is needed. When you get close to it, we'll discuss in details.
Formula One Spin Doctor
From my experience get the Piggyback with timing control as soon as you can. Fuel quality has a huge impact on how advanced the timing can be from what I have seen on my car. For my own car I know I don't have timing optimized but I can say that with the standard fuels available around here and the variability of even the premium available from station to station I had to pull timing way back in the torque curve peak area to be able to run even 13psi.
My experience has shown the long stroke and bigger bore do make the timing map very critical. John may have your chips already set for this, but if you are having problems running over 15psi and assuming you are using higher octane gas such as equivalent to the North American rating 98 octane I would be cautious from what I have seen on my car.
The maps he has are set for 15psi on pump gas. He also has a set of maps for race gas and higher boost. Running more than 15psi on pump gas on the race track is not a good idea. Yes, the timing can be pulled, and he has the PB to do it, but other issues will show. High intake temps play a big role in detonation not just timing.. Heat soak the intercooler and all sort of issues will pop. We must look at the big picture.
