Another Gas Smell Issue
Ok,
Here's the problem. I've installed Russell's chips,3bar fuel reg,and a boost controller When at fullboost (15lbs) 3rd gear, I get a strong raw gas smell in the car. It doesn't happen in the lower gears and I don't know about the higher gears. Trying to think this through,I'm guessing either the injector seals are leaking or the fuel reg. is leaking at the rail. This didn't show up untill I installed the chips,3bar and the boost controller.So do I pull the injectors and send them to Whichhunter for a rebuild or do I mess with the fuel rail. I've got all winter to do this,as the car is put away untill April. Car has 58k on it but is still a 21 year old. TIA, FRED
I've give Russell the benefit of the doubt since it's impossible to know if the chips doing it's job without a wideband. No doubt your pushing more fuel now hence you'll notice the leak that was pre existant. The chips aren't going to cause a fuel leak and if you're leak free the only way you'll smell fuel is out the tail pipe under rich conditions. All high gear smell means the fumes are being blown into the cockpit at that speed. Time to invest in a wideband my friend and get under the hood and find the leak. More than likely it's your injectors.
Fuel rail leak is what I thinking also. Doesn't the fuel pressure increase with boost ?? Or is it always at 3bar nomatter what the boost is ?? Also when you change fuel regulators or injectors,does anyone put some kind of lube on the seals ?
Try to get the seals to do their job dry but I have put Hylomar on a tricky injector o ring that I couldn't get to seal for the life of me. It's a gasket sealer that will not dry. Very good stuff.
