KW Variant 3 coilovers: A short review
#106
Chris, some good questions there .
I am not 100% sure on the spring rates yet, i need to do some more reading but there are a handful of good threads on the 968 forum aswell as the UK based Porsche forums. There is a thread posted by Karl Glynn in the 968 section that has some very informative links. I suppose i could also contact KW directly and ask them what they think will work with the torsion bars gone. DVC said he was running 500lb in the back with deleted torsion bars and mentioned that KW said it was fine with the valving they come with.
As also mentioned in this thread, i am going to buy them through Autotalent probably. I contacted them Oct. of last year asking for a quote and they told me $2290 shipped. I was going to buy them over the summer but ended up moving down to TX. I am sure that price has changed and will email them again in a couple days to see where its at. If anyone has leads on good suppliers for the KW suspension please do tell. I have checked Vivid Racing and Speedware but they all are list price at ~$2800.
My concern about the lower shock bolt is the KW has what looks like a typical rubber bushing style end. The 'upgraded' shock bolt from RE requires a spherical type end. I remember reading about people modifying the Bilstein Escort rear coil overs to a spherical type bushing (it comes with a rubber type like the KW) but wonder what everyone was doing. I would like to delete torsion bars for sake of simplicity, some weight loss and no need to screw around with trying to reindex and get the right ride height. However it seems the KW setup is pretty well thought out to be run with torsion bars.
Frankly i am just lazy and dont want to be bothered reindexing the torsion bars.. i figure its just easier to take them out completely . I probably will never adjust the ride height again after installing and having the car corner balanced. I am very much a set it and forget it type when it comes to my suspension setup. However i did read a few accounts of 'funky' handling due to coil over / torsion setups if not setup correctly. Id hate to have one of those funky handling rear ends.. .
I am not sure about camber plates yet. Honestly i will probably never screw around with the adjustment on them. I usually run around 1.5-1.75 negative camber on the front with zero front toe and have done this for a couple years and many street miles. I saw very little uneven tire wear and am not worried about that really. Plus i dont like how its essentially not possible to adjust the camber via the plates without changing your toe. It seems like its a compromise either way (camber plates or no) you go. I also have no need to run mega front negative camber, so the extra adjustment is not a factor for me. I ran the KLA monoballs on my n/a and liked those, i think they are a great alternative to the factory mounts which are like $400 each (KLA were around $200 for the pair last i checked), also no rubber which is always a good thing. I was going to replace all the bushings with the exception of the banana arm (going to leave stock rubber). It was going to be a mix match of RE, Elephant Racing and the group buy torsion carrier mounts i bought. Probably not this year, but probably next i want to go with the RE control arms and bushings in the front to finally do away with the alloy Porsche arms. Its not a high item on my list as one of the PO's of my car replaced the arms with factory new 968 arms at the tune of about $1k about 20k miles ago.
Its going to be a huge job. I need to replace my torque tube also, so i was planning on dropping the entire rear suspension, transmission (need to install new trans mount also) and wrestle the old torque tube out. 'While your in there.."
Thankfully this car is not my daily driver anymore, but i know i am still going to drive it as much as i can on the street (easily 10-12k a year)whenever i happen to move back to NY. That plus it still needs to get me to the track and back home..and all track ventures mean i need to cut through Manhattan or take the Cross Bronx to get on the GW... and both of those roads just plain suck. All i know is i need to ditch the Koni / stock spring setup on my car right now. The car is just way to undersprung.. on tight auto-x turns and also going into the bowl at Pocono the front splitter actually drags on the pavement from the amount of lean the front end has. I thought my wheel bearings wear toast at one auto-x as all i heard was this awful grinding / scraping sound on hard cornering, then one corner worker told me my front end was touching the pavement!
What spring rates are you going to use? (Standard V3 kit comes with 340/285, but if you're going to delete the TBs, you'd need a stiffer rear spring, as I'm sure you know.) Do you know how much of a spring-rate range the standard valving allows?
If you don't mind my asking, what's your source and price for the KWs? I thought I had a source online with a price of $1795.50. Had it in the cart and checked out. Asked them to verify that it was #35271010. Got an email that it was the right application listed in the cart, but the wrong part # in their order process. (I was never presented with a part #. Just their application wizzard.)
Don't know about the rear lower shock bolt, but I'd have the same question if I were going to delete TBs. The KW bolt looks similar to the RE, and I assume it's TUV approved, but it warrants consideration. I'd probably get the RE, just for peace of mind.
Are you going to use adjustable camber plates, fixed monoball mounts (not sure what the point is, if it's not adjustable), or stock rubber? I plan on sticking with some new rubber mounts, since it's a daily driver.
I'd also plan on replacing hardware (bolts, nuts, etc.), along with bushings. I've read that the rear spring plate bushings take a lot of abuse when the TB isn't there. Many recommend the polybronze bushings, but they're expensive.
#108
No Mark, he has unfortunately long since given up the distribution and got out of the business. I know some guys down south in Sydney who have the agency but haven't spoken to them about this. You could give them a call. Ask for David. East Coast Suspension.
http://www.eastcoastsuspensions.com.au/
#109
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
I've a little problem with my KW, on 1000km the camber increase itself.
So I make a camber ajustement, when I disassembled the excentric bolt, I see that the wascher was deformed by the round part on the bold. This cause probably less tightening and let the camber play on hard load.
I use now original new porsche bolt (which is a bit shorter), washer and nuts and notice any problem ;-)
If not, is Alex's suggested fix above still considered the best unofficial advice available? Has Glen Messenger &/or Tom Edge at KW USA offered any advice/opinion?
We should probably try to get this issue nailed down once and for all...
#110
I realise this issue is going back to August/Sep 2008 now, so has there been any formal word from KW on it to anyone's knowledge? A techical bulletin or equivalent?
If not, is Alex's suggested fix above still considered the best unofficial advice available? Has Glen Messenger &/ Tom Edge at KW USA offered any advice/opinion?
#111
It looks like I started this thread in '07. I must say, after constant daily use, my V3s are still performing brilliantly. Wouldn't hesitate buying them again.
#113
#114
I had a problem with the adj camber plates too. Nothing major, but still somewhat disappointing.
#115
Hey Travis, what was the end result of all the crap you had to go through? That same thing happened on mine too. KW Germany knew about it, but I didn't want to send them back over there. We wound up welding those 'U' grooves into place.
I came to the same result as you, Patrick. They wouldn't fix it unless I sent it back to them first (disappointing considering it's a Known issue). I think it's important to find a good dealer to be the middle man though. I had great service from AutoTalent. They were even going to cover my shipping the unit back. I guess I should have taken them up on it instead of fixing it myself. At that point I was really strapped for time and didn't have a spare. Good thing they work so well.
#116
Hey Guys,
After reading this thread and a couple of UK based site I have a couple of Q's.
1. Is anybody running KW3's on a TRACK CAR with spherical bearings and t bar delete?
2. Who did the bearing install?
3. What is the spring rate for the rears and how did you come up with that rate?
Cheers,
Cheers,
#117
In my experience and I've asked heaps of people there is no Australian agent can supply decent suspension for reasonable money .and when i say reasonable i a,m willing to pay +30% than the US price
have it sent in 2 or more parcels 25kg is the limit for manual handling and also it is also at the piont customs jumps on it have it declared no parcel over about 900Au lindsey racing and Eshocks can't realy be beaten on price ..
#119
#120
I can't see that it would be much of a problem to have someone break up the kit from the OE packaging and sending them down in smaller parts?
I think V3s are available for about $2200US? I've heard somewhere near $5k+ for them down here.
