CEP dry sump
Let's all wait until Dave posts here, before there's anymore speculation. I'm sure he can give us a lot of insight about his CEP kit. And some information on Special Tool's set-up too.
Basic Sponsor
Tool, that's a beautiful engine, where did you get it from?
Pan is CNC machined, pump can mounted either side, a smaller lighter alternator can be used for track car, then you have hoses, tank, etc. David has posted these before so I don't think he'll mind.
Rocket Scientist
And with that pan AND turbo from CEP, that's just too much car for you to handle.
BTW, that pan is a NEW CAST piece then CNC'd. Not even a rocket scientist like me could have designed something so beautiful and delicious. Dave's my hero.
[QUOTE=special tool;4612128]There are a couple of neat tricks visible in this photo, the practiced eye might spot them......QUOTE]
The extension holding the stand from spinning?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
[quote=special tool;4612128]There are a couple of neat tricks visible in this photo, the practiced eye might spot them......QUOTE]
Maybe its the loose turbo mounting bolt...
What PP is that ?
I was thinking the same thing Hos, ST runs down to the dyno, does a few pulls and decides he needs a couple hundred more HP, drives home rips the engine out
Press on ST
Press on ST
