2bridges Bonneville results
Old 09-19-2007, 02:32 PM
2bridges
2bridges's Avatar
Billthe3
Ahhhhhh - I follow.
Well I can say I spent hours scraping salt off of the tow rig and car after four days of salt events.
Then about $15 at the local power wash. Yes the salt can be a bear to deal with. Especially if it is wet.... when it dries it turn to a concrete like material. The 951 was not horible, but the truck got **** everywhere. Back bumper was nearly full.
I also hand washed and spray waxed wheels daily. Stuff is very sticky.
Old 09-19-2007, 02:45 PM
George D
George D's Avatar
OT, but one of my favorite movies is, The Fastest Indian. Those of you that haven't seen it, should do so. Salt Flat top speed runs using a 1920's home made Indian motorcycle. Anthony Hopkins does a great job starring in this movie.
George
Old 09-19-2007, 02:49 PM
2bridges
2bridges's Avatar
George
X2 - LOVED IT!
Old 09-19-2007, 03:32 PM
2bridges
2bridges's Avatar
few more pics as requested
Old 09-19-2007, 03:51 PM
2bridges
2bridges's Avatar
check out this datsun B210......... or at least that is how it started life. Now a blown flathead ford powered altered.
Old 09-19-2007, 04:50 PM
special tool
special tool's Avatar
awesome!
Old 09-19-2007, 04:58 PM
TRP951
TRP951's Avatar
looks like it was a blast.
Old 09-19-2007, 06:10 PM
2bridges
2bridges's Avatar
one more nice pic
Old 09-19-2007, 07:19 PM
RolexNJ
RolexNJ's Avatar
That is just nuts! You got to have a big set of ***** to hit those speeds on that type of unstable surface. Kudos to all of you guys!
Old 09-19-2007, 09:42 PM
SD Porsche Fan
Cast Iron Man
SD Porsche Fan's Avatar
Originally Posted by RolexNJ
That is just nuts! You got to have a big set of ***** to his those speeds on that type of unstable surface. Kudos to all of you guys!
Exactly what I was thinking. I don't think I'd have the stones to go through with it. Way to go 2bridges!
Hey, are you going to Renntreffen this year?
Old 09-20-2007, 01:23 PM
ausgeflippt951
ausgeflippt951's Avatar
That's awesome. What is the conversion again for slip experienced due to the salt? 10%? I forget, but it allows you to convert to a "would-be" asphalt track to give you a point of reference.
neat.
George -- can I come?
Old 09-20-2007, 01:47 PM
2bridges
2bridges's Avatar
[QUOTE=ausgeflippt951;4594500]That's awesome. What is the conversion again for slip experienced due to the salt? 10%? I forget, but it allows you to convert to a "would-be" asphalt track to give you a point of reference.
QUOTE]
Yes many salt racers use a +10% wheelspeed to calculate pojected actual speed. They also generally make much more power and are on a skinny 4" treadwidth tire for stability.
My car did not seem to experience too much spin at the top with 245 or 225 tire.
Don't have any data logging and had my hands full so I was not able to know exact rpm through the timing lights. Think the highest rpm on last run was about 6,000rpm. in 5th on 225/50/16 tire and 8" wheel. My math indicates I shoul have been running about 158mph and timing showed 156.99.
Old 09-20-2007, 01:50 PM
Bill
Bill's Avatar
2bridges...representing 951's strong!
From the tricks you performed to gain speed, it sounds like you have done this before? Are you now officially the "Fastest" 951 on the salt?
Way to go!
Old 09-20-2007, 02:47 PM
xsboost90
xsboost90's Avatar
dude i so want to do this. Get some 16x7's all around and head out there. What kind of tires would be best on the salt?
Old 09-20-2007, 03:07 PM
2bridges
2bridges's Avatar
Way to go!
Thanks Bill! nah I was a salt rookie. And as much as I would love to claim "fastest 951 on salt" - not even close I am sure. In fact the mild modded turboS (exhaust, chips, etc) had one run of 158mph, faster than my fastest 156.99mph..... without any of the antics we did to get it done.
Maybe, just maybe, the fastest true street, gaurds red, k26/6 turbo'd, 951, from Nebraska, on the salt ..... maybe ]
XBOOST90
- Do it man! be well prepared and it will be a great time.
From my experience and discussion with USFRA staff and racers - skinny well treaded tires (speed rated of course) perform best. I would not prefer "slick" or shallow treaded type tire. Also a taller tire may be beneficial from a directional stability perspective. Don't know how fast you want to go, but the 150 club is an awsome way to get a taste of salt racing without building a dedicated car. - What are you waiting for ... DO IT!
__________________EDIT____________________
For refrence - I ran two tire setups
Hankook RS2(front and rear) 225/50/16 & 245/45/16 - 42psi front - 40 psi rear
khumo MX tires (front)205/55/16 with Hankook(rear) 225/50/16 - 50psi front 50 psi rear
Certanly do-able - but really can be a handfull until track dries out after numersous cars have run. Also a handfull late in the day - track gets a bit loose and rough.
Also I ran an LSD trans. After the experience I am glad I went ahead with the trans swap.
Quick Reply: 2bridges Bonneville results
