Who has the AIR brake cooling ducts?
Old 08-06-2007, 05:59 PM
TRWright
TRWright's Avatar
Default Who has the AIR brake cooling ducts?
The ones that sit in the foglight holes. . .
http://americaninternationalracing.c...alleryid=43737
I want to hear about the fitment and quality.
I called to order them, and the way the dude was talking scared me. He told me that they 'would be ok for a race car, but I may not be happy with them on a street car' I asked him to compare the fitment/quality to the splitter they make, and he told me that you 'can't even compare them, one is for a race car one is for street.'
Pics would help as well. . .
Old 08-06-2007, 06:24 PM
OriginalSterm
OriginalSterm's Avatar
I have them. The fit isn't great, I had to cut/file/sand/dremel the outer edge to get them to fit the way I liked. Plus, mounting is totally up to you. The plus side, I think they work pretty well as moving a descent amount of air. I haven't noticed brake fade since I installed them.
Old 08-06-2007, 06:25 PM
Judson951
Judson951's Avatar
I think tifosiman has them... Good luck..
Old 08-06-2007, 07:58 PM
daigo
daigo's Avatar
I just put mine on today. I had to fit one side by sanding the edges, but not too bad.
Old 08-06-2007, 11:55 PM
Oddjob
Oddjob's Avatar
I had to sand down some edges and add fiberglass material to the corners to get them to fit. Took a lot more work than it should have to get them to fit.
Old 08-07-2007, 07:47 AM
Jason Judd
Jason Judd's Avatar
Why not use the OEM 993 part instead?
I fit those on my 968.
Jason
Old 08-07-2007, 08:50 AM
333pg333
333pg333's Avatar
Any idea on that OEM part number off the top of your head Jason?
Old 08-07-2007, 09:22 AM
Jason Judd
Jason Judd's Avatar
Patrick,
I got them from Paragon. Their part number is item#900228; identified as 993 Brake Cooling Duct.
Jason
Old 08-07-2007, 10:09 AM
Oddjob
Oddjob's Avatar
Jason
Because the 993 and 968 fog light openings in the front bumper cover are about 1/3 the size of the 944T/S2 foglights.
Old 08-07-2007, 10:11 AM
Jason Judd
Jason Judd's Avatar
Oops...didn't know that.
I thought they were the same size as the 944T.
My appologies.
Jason
Old 08-07-2007, 03:24 PM
TRWright
TRWright's Avatar
Greg-- thanks for the pictures
anyone else have some (maybe high res or close up) pics of how they look?
TIA
Old 08-07-2007, 03:34 PM
OriginalSterm
Ted, I'll get some close ups tonight if you'd like.
Old 08-07-2007, 05:49 PM
mj951
mj951's Avatar
I added a pair of AIR brake ducts along with twin ducted oil coolers this past winter. I fabed up some aluminum mounting brakets off the old fog light housing and used a 45 deg. silicon hose off the back of the cooling duct to extend back over my oil cooler ducting where i transition to 3" flexible racing hose.
Old 08-07-2007, 06:25 PM
333pg333
333pg333's Avatar
I realize there is a funnel type action happening on those ducts, however they have a lot smaller aperture than the rectangular stock 951 ducts. I am now trying to marry up the stock ducts with a part I bought from Pelican that leads into the 3" duct hose, then onto those backing plates with the same sized spigots. This doesn't look like a straight fit but I can't see what else you would join these new pieces to? I haven't seen them in the flesh yet so maybe it will become more apparent. Anyone else used these?
Old 08-07-2007, 06:49 PM
TRP951
TRP951's Avatar
have you though about the 968 cooling scoops ted? I heard those work well
Quick Reply: Who has the AIR brake cooling ducts?
