Intercooler questions
Originally Posted by mtnman82
In the interest of adding to the discussion, what is the consensus about upgrading the intercooler on a 'mildly' modified 951, say something with a K27/VR stage 2 or 3/similar, and supporting mods, putting out 300~350whp? Would upgrading be worth it in such a case?
I assume something like a 3" exhaust should be higher on the list than an upgraded intercooler?
Ehall, I listed my mods..
I consider them pretty average.. It is a solid car with a newish (50k) engine at this point.. It runs strong.. pretty much all the trouble areas on the car have been addressed at this point as well (new fuel lines, axles, ignition, and best of all not more starting problems)
Mod wise all I really have left on the docket is Intercooler and vitesse stage3.. Then the car is done engine wise.. suspension is done.. interior is almost done.. then it hits the body shop
I am not quite ready to do the new turbo yet.. but I will soon..
So the "your car isnt fast enough for an intercooler game" doesn't apply here.. It will be needed soon
I guess my point is no one is going to talk me out of this
1 Post
this may be a stupid question, but i think it makes sense.
couldnt you intercool an N/A car? colder air helps boost hp dosent it? even a little?
i know turbos cause heat which is why theres an intercooler, but wouldnt it be like aa super cold air intake on an N/A?
If you are pulling air from a cool place in the engine bay, how much cooler would it get running it through a heat soaked aluminum box? Answer.....it wouldn't help at all.
1 Post
kind of make a "custom" cold air intake and just using that as a section of the pipe
Venting nose panel, “improving” Porsche’s IC design and adding a larger intercooler are frequent topics here. It is actually puzzling that I have not seen a single post trying to quantify the “improvements” through actual measurements.
The irony is, that I have a thermocouple (EGT sensor) in the exit of the turbocharger compressor and another one in the intake manifold (IM) boss, just after the throttle body and can switch them to my EGT gauge. Unfortunately the gauge is analog, so the reading accuracy is quite bad at the relevant temperatures.
However, I can see that under boost the turbo air temperature quickly goes to the 300F range while the IM temperature stays virtually constant. It actually stays so constant, that I found it necessary to test its functionality, which I did today with a lighter and sure enough, both sensors work just fine.
In other words the IC does an excellent job at air cooling even with a K26-8 at 25 psi and without nose panel venting. Maybe others will make an effort measuring the pressure drop under driving conditions.
Laust
Laust
laust, I had some actual measurements (power on dyno) on the larger IC I tried... there should be a thread somewhere... zero HP gain over stock, I was within 1HP of the stock IC power.
It's not my quote. I found that funny as well. lol
A person probably shouldn't give crap to another guy about his car when he doesn't know how to even spell the model name. lol
Typical of the many idots hiding under the bridges of the OT section.
Now that you mention it, I very vaguely recall something to that effect, but do recall that you actually made efforts to quantify various modification.
So I stand corrected ... for this once
