turbocharger review - pauer tuning
#46
Originally Posted by nize
vic will disclose full specs when you're ready to buy. john will not. that's the difference i ran into.
also, vic will custom-match a turbo for your goals. want a 50trim with a #6, 8, or 10 hotside, vic will do it for $1500. want a 60trim? he'll do that too. john has a mystery 'stage2' with no alternate configurations for $2200.
big difference there also.
As for John's different configurations I guess you could say they are Stage 2, 3, 4 & 5 which is basically what you are saying you can do with Pauer by changing the wheel trims and housing sizes. Perhaps the Pauer model allows for larger variations in performance however I would suspect that if he was selling a tuned bolt-on package he would have to stay with certain known configurations to keep everything safe and predictable. Not everyone is going to have the ability or system in place (EMS) to actively tune an engine.
Again I'm not trying to be insulting. I'm just trying to make sure we are looking at things fairly. I really do look forward to seeing your results. Are you planning to make the maps from your Wolf available for other guys here who might want to follow in your footsteps?
#47
Originally Posted by sh944
You've been on Rennlist long enough, I am pretty convinced you are committed (as is Nize).
The problem with MAP is that it responds to quickly for the Motronics units. MAF sends a compatible signal, MAP doesn't. The best you can do with MAP is try to fool the DME, MAF talks the same language.
The real glory with a 951 is going to be found in a standalone system, I'm convinced of that. Still, with a Kevin Gross built tranny (complete with an S2 r&p) and Johns turbo equipment, there aren't a lot of cars that will hang with me.
Regards,
Regards,
And I beleive if you are talking about Tedwrights car that you bought from him that thing had quite a bit of power
#48
Nope. I didn't buy Ted's car. You must be thinking of someone else.
Regards,
Regards,
#50
I just had an interesting thought. Does anyone ever publish the specs on superchargers? I just bought a 93 NSX with a Comptech supercharger. Now I know that the supercharger is a Whipple blower and I know that it has the smaller (low boost) pulley but I can't say that I have ever heard of anyone saying what the exact specifications are for the internals of the blower. Is this because there are no specifications (lack of variety that you have in turbo selection) or is this because in the supercharger world nobody cares and all they want to know is how it performs? Just wondering.
#51
Originally Posted by A.Wayne
Power numbers please . this would be a better comparision tool than PSI ,
could you post you dyno sheet at 23 PSI ....
#52
I'm running a widefire with a stock shortblock on pump gas, so no 23psi runs for me, but I will give you an honest 17 psi run in the next several days, as long as I get a chance to break away from my day job.
Regards,
Regards,
#53
Tell you what, I'll post a dyno chart, if that doesn't convince you its the real deal, then I can't help you and I don't really care. Fair enough?
Oh, and I can sleep plenty well at night, thank you.
Regards,
Regards,
nevertheless, i'm still curious to see your dyno. i don't understand why, when we're all 951 owners, enthusiasts, and customers, we have to be so secretive towards each other. where's the brotherhood? we should be helping each other, not bickering about magical mystery products.
#54
Originally Posted by 333pg333
Sorry if I missed it, but did you have all the mod's on while you still had the KKK? If that's the case then isn't it a direct comparison between the turbos?
#55
Originally Posted by SoloRacer
How does he determine if you are ready to buy? Does he make you give a none refundable deposit? If you are keen for the specs wouldn't you want to know before you buy? Do you have to sign a non disclosure agreement? It doesn't make sense to me to say "I like knowing the specs but I won't get the real important ones until after I buy" It's sort of like saying "GM will build me a car but won't tell me the specs until after I gave them my deposit". A better approach would be "Here is a Corvette - it does 0-60 in 5 seconds and gets 35 mpg." At least then you are basing it on the results - not the specifications. I wouldn't care if the car had a V8 or a supercharged V6. It's the performance that matters. The only real point in knowing all the specifications would be so that you can purchase a turbo from another vendor for less money and that is why you won't tell us what Vic is doing. Again I have no problem with that as it is his livelyhood. I just find it a bit hypocritical to be demanding someone tell you all the specs of one product and then defend not telling all the specs of another. Just my point of view I guess.
as for the specs, i've already told you and everybody else the specs that matter the most. why don't you be fair and tell us the specs of a vitesse stage2? or do you not even know what the specs are of the turbo you have? do you know how many cylinders and displacement your motor is? maybe you don't care, but this type of information is critical to tuners.
#56
#57
I would also like to know the conditions involved in getting the dyno sheet numbers (pump gas, exhaust, head work, etc.)
#58
#59
yes. i'll point out once again that the only difference in my turbo comparison is the turbo alone. nothing else changes.
p.s. Changing to the S2 cw&p is a great modification provided you don't need to travel at 275+kmh. It just gives so much better response and probably lets you run a larger turbo while retaining good response all through the rev range.
#60
Hey Man
How does he determine if you are ready to buy? Does he make you give a none refundable deposit? If you are keen for the specs wouldn't you want to know before you buy? Do you have to sign a non disclosure agreement? ...
I just can't see why many of you seem somewhat concerned about someone trying an alternate source for turbos. Vitesse, Lindsey, SFR; they are all good companies that support the 951. Pauer Tuning to me is no different, another good company, a smaller product line maybe, but with a few well thought out products none the less.
