side mirror removal - Rennlist - Porsche Discussion Forums
side mirror removal
Old 04-19-2007, 02:02 PM
user323
User
user323's Avatar
Default side mirror removal
hello everyone
quick question im removing the driver and passenger side mirrors and was wondering how to get the harness through the mirror assembly or where to disconect it in the door any info would be great pics would help too if any
thanks
user323 is offline
Old 04-19-2007, 03:01 PM
MichelleJD
Jane Bond 007
MichelleJD's Avatar
I believe you have to cut off the harness. Go to icat's DIY (in his signature).
MichelleJD is offline
Old 04-19-2007, 03:05 PM
MichelleJD
Jane Bond 007
MichelleJD's Avatar
Old 04-19-2007, 03:43 PM
Techno Duck
Super User
Techno Duck's Avatar
Unfortunetly you do need to cut the harness off. I still wonder why Porsche did not make a connector inside the door to make life easier. I still havent hooked up my power mirrors, probably never will!
Techno Duck is offline
Old 04-19-2007, 03:48 PM
PorscheDoc
PorscheDoc's Avatar
You do not need to cut the harness if you have the correct tool to remove the pins from the plastic connector.
PorscheDoc is offline
Old 04-19-2007, 06:40 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
So this is true then, i thought the PO started messing around with that.
hosrom_951 is offline
Old 04-19-2007, 07:23 PM
fortysixandtwo
User
fortysixandtwo's Avatar
Yup, I used my pin/socket extractor tool kit last week to pull my mirrors off.
I am also surprised that the mirror connectors were populated as part of the same sub assembly as the mirror installation. They must have used a functional check of the mirrors opperation to verify the wiring.
....well it sort of makes sense, considering there were no optional mirror styles.
fortysixandtwo is offline
Old 04-19-2007, 07:35 PM
Mike951
Super User
Mike951's Avatar
If you already cut them off i have 2 sets of window wiring harnesses.. if not you can pop the pins out of that white cirular connector, then feed them through.
-keith
Mike951 is offline
Old 05-08-2007, 02:30 AM
motoxxxdeamon
motoxxxdeamon's Avatar
Hello, I was searching about how to remove my mirrors and came accross this thread and want to avoid cutting the wires if at all possible. Where is this white circular connector located?? Is it inside the mirror somewhere or is it inside the door panel??
motoxxxdeamon is offline
Old 05-08-2007, 02:31 AM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
it's in the mirror.
Mighty Shilling is offline
Old 05-08-2007, 03:09 AM
motoxxxdeamon
Thanks! Is the pin/socket extractor tool a common tool that I can buy at Sears/Walmart/Autoparts store?? Is there a specific one that I will need for this job?
Old 11-02-2018, 02:34 AM
tcporsche
New User
tcporsche's Avatar
Hi Moto, I am looking for the same mirror electrical connector pin removal tool and also how to use it...I purchased a kit of them from Amazon but none of them seem to work? I think I need a real small diameter hollow tube tool but the ones I got from the kit are either to big or to small! Amy information you can pass on would be appreciated. BTA my name is also Casey,first name Tom Thanks and best regards, tcporsche
l
tcporsche is offline
Old 11-04-2018, 12:08 AM
steven74
User
steven74's Avatar
Dear Tom,
Welcome to Rennlist! Unfortunately, the thread you referenced is over 10 years old so unlikely to have a response from the OP. However, the pins you are referring to do have a specific terminal removal tool. Also, make sure the lock is open on the terminal in order to release the pins. I have been looking at this set to purchase for home use.
Amazon Amazon
Best of luck.
Steven
steven74 is offline
Contact Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
