Standalone EMS...?
#482
Guess what's under here Dukey?
#484
#485
I thought the G4 Storm would not get all the different triggering features, much like the regular G3 did not before. It was just the G3 Plus that had the 951-triggering.
But I might be wrong about that, maybe all versions have the same trigger-options now with the G4.
#486
Duke,
Yes, the g3 and g3+ all use the G4 software. They all use 944/944t, 132 tooth triggering and factory ref sensors.. I use the standard G3 and it runs the factory triggers. I now run the G4 software and it works fine. Thats the beauty of this system, constant free upgrades and factory triggering.
#488
The "knock block" can be used as a complete standalone without anything else. You install a second knock sensor and plug it in. It puts out a 0-5volt signal and also an audible tone that you can hear with headphones. Its great for tuning and logging/monitoring.
#490
So have you been using your KnockBlock successfully Brian? Does it give a count?
ps you'd get in trouble for your avatar in OZ
#491
Well it doesnt count anything itself. It outputs a 0-5V signal to my MegaSquirt which then handles all the timing retarding and stuff however I configure it to. So yes theres a count, but through the MS log.
#493
So have you seen many counts happening to draw any conclusions?
#494
