Standalone EMS...?
#181
Is it possible to run an EMS in conjunction with this knock controller? I have read a bit on this and it seems very good.
http://www.jandssafeguard.com/
#182
well that depends if you ecu is able to do somthing effective with the knock signal . I'm working on it at the moment when i get back home see my thread "how klr inerphases with dme"
but there are heaps of knock moniters you can get to hook to the sensors left on the block you can then hook them up to a massive shift light with a $ sticker on it to get you lift your foot .
#183
Originally Posted by gt37vgt
well that depends if you ecu is able to do something effective with the knock signal . I'm working on it at the moment when i get back home see my thread "how klr interfaces with dme"
but there are heaps of knock monitors you can get to hook to the sensors left on the block you can then hook them up to a massive shift light with a $ sticker on it to get you lift your foot .
I suppose you could just run those 2 independently or in parallel? Did you check that knock controller out, it looks very good to me. It used to be, or still maybe sold by Lindsey. It would be interesting to hear from anyone who is running it?
#184
It takes the ignition signal from the ECU whatever it may be, then delays it if theres knock before passing it on to the ignition driver (coilpack, etc etc).
#185
To say there is no such thing as belt stretch is no right. However, this is something that is more thought to happen than actual. I know that when I used this system there was no signs of stretch. It was checked on the dyno at all speeds. The testing was done to see how big to make the teeth in width. This way, if any stretch was present. the tooth would never leave the sensor.
As for 24-1, this was chosen as its a common tooth count and the software was already written. The missing tooth gives the sync and on ther Cam allows for sequential fuel and Ignition.
The system I use can run the factory sensors, 60-2 on the Crank, 12,24,36 etc. It all comes down to what triggering the system can support. I chose the 24-1 as I wanted sequential control and saw no reason to fit another wheel to the crank and one on the Cam.
A Wayne, PM me and I will tell you who to call for the sensors, the wheel etc.
#186
#187
#188
Did you check that knock controller out, it looks very good to me. I used to be, or still maybe sold by Lindsey. It would be interesting to hear from anyone who is running it?
#189
so does it pull timing like the klr i remember considering it years ago and for what it costs your better served going with high end ecu that has it on board
link motec autronic.
i still think i will be able to use the klr when with my ems when i do the research
#190
it does pull timing even better than the klr. up to an insane 40 degrees which is more than any other standalone, although anything over 20degrees is overkill.
it can even pull boost just like the stock porsche system, which no other standalone ems can do so far.
read the reviews i've linked in my earlier post on here.
maybe it's just me, but i'd rather go with a product from a company that specializes and lives and dies by knock control rather than a one-stop-kmart-style-shop ecu that attempts to do it all and does it poorly.
motec is great, but it also costs double the price of the wolf and is still not plug-and-play nor is it easier to use.
#191
Small Business Partner
Unless the J&S is a 'special version' made, then it is limited to 20degrees of ignition timing retard @ 2degree increments. (selectable to 1degree increments for a total of 10degrees retard).
Rogue
Rogue
#192
with the high end ecus like motec and autronic you are limited only by your imagination you can programe and input to to change any output anyway you like directly or inversly . a motec or autronic can do it toochay nize but yes you do need to be a profeesor of efi to do it yes its tricky. But the LINK nz ecu does run knock conrol and does pull timing and boost .
And as for one stop kmart shop ecus compared to the almighting safe gauard gurus
SKOFFF!!!
Motec wrote the book on all things efi in 1984 and then some of those guys started Autronic and all of them would take safegaurd to school.
SKOFFF!!!
#193
My understanding from talking to Motec and Autronic is that they don't yet have knock control... Motec said they can only log it at this stage and the Autronic distributor said it's planned but that has been the case for the past couple of years. In any case, Wolf is also has a knock control module that will be released once testing is complete.
There is also a new J&S model.
#194
using my soap box to step down off my high horse for a minute to ask . so the wolf is working out ok for you guys ??
i will give them credit they are the only one i know that offer 944 in kit form .
and you say you have heaps of spare out puts so if you run 4 injector outputs and four coils how many spare outputs do you have to run boost control etc ?
i feel i was a little hasty ruling it out for lack of gimmiky antlag
and it seemed to cost about 30% more than what i have with antilag.
but if the expierence of applying the ecu is easy to access as it seems to be for wolf you cant put a price on it .
My ecu is better in "theory" than the wolf but until it runs on my car i'm full of **** .
someone should have told me
