UK 3.2 Turbo hits the road
#196
Did a diesel really win LeMans??
Just wait until I tell my wife when she next complains that I drive a Porsche and she takes the kids to school in a diesel people carrier! (she has a boxster for weekends, so she can't complain!)
Has anyone done a back to back dyno test of something like a LindseyRacing intake manifold? or are there other ones out there?
#197
Originally Posted by RennBod
Did I miss something or is this car really running a 2.5 modified chip, 2.5 exhaust, 2.5 intake and just about everything still 2.5?
I was without a 951 for 18 months and when it left me it had 280bhp which was plenty fast enough at the time. I did not want to get it back and straightaway become a 600bhp Special Tool rival because I know that I would not be capable of using it. What we have now is a work in progress and it is already delivering much more than I hoped with just a 'simple' engine swap. It is very driveable, very docile, very smooth and it is completely unbothered by whatever gear you are in and whatever the Tacho reads - if you slam your right foot down, it flippin goes like stink
I'm looking foward to its development when it will get even stinkier
#198
And back to back what? Stock Manifold versus Lindsey, JME, SFR or what?
Sorry Paul....
#200
Back to back testing of the LindseyRacing manifold versus the standard one... or the standard one versus anything else.
Cheers.
#201
The one minor downer for me yesterday was being unable to hold a level 15psi boost level to the redline. I had really hoped that the Greddy EBC would enable me to do this but unfortunately thats not the case:
Jon has already explained its because of the massive restriction at the AFM and the poor turbocharger simply can't suck enough through there to feed that air hungry 3.2 once the revs start to get high. Luckily we all know the ultimate solution
#202
Originally Posted by Diver944
Jon has already explained it's because of the massive restriction at the AFM and the poor turbocharger simply can't suck enough through there to feed that air hungry 3.2 once the revs start to get high. Luckily we all know the ultimate solution
#205
Originally Posted by Duke
Although I disagree on many of your statements I won't turn this into a intake manifold design thread.
But you should know better than to give credit for a race car's lap time to the engine, diesel or not.
Please answer me this, do you disagree that it's the average horsepower in the used rpm-range that determines how fast the car will accelerate?
Hey Duke.
PM Sent. But in short I answered your question in relation to torque. You mentioned diesels as if they provided torque but no performance. If you would like a comparison closer to hoime I know somebody who builds 3.0litre BMW diesels for use in race applications they are putting out About 340 bhp but about 500lb/ft torque and are used in certain competition applications in preference to petrol V8's. Why because of the usable torque curve.
HP is important but torque is the single most important factor unless you live your life over 5000rpm. Then HP becomes critical in its own right
#206
BTW I just modelled this engine and got almost the exact same numbers... Time to play around with some of the "unsuitable" parts
#207
Originally Posted by tommo951
What modelling software do you use?
#208
#209
I think Paul plans on removing the restrictions from his car one by one in a scientific and quantified way so he can see each improvement with a car that will grow with him.
I would probably recommend Paul removes the restrictions in the following sequence.
1. Ditching the AFM in favour of a MAF.
2. Replacing the exhaust after the turbo with a larger bore free flow system
3. Replacing the intake manifold with a more suitable item
4. Replacing the exhaust between the head and the turbo with a better manifold and crossover
In some ways I would love to get a chance to datalog some pressures and temps on Paul's car from various locations, such as throughout the intake and exhaust.
I think a lot of the problem with pauls car dropping the boost is down to excessive back pressure post turbo causing a poor pressure ratio over the exhaust, and an excessive pressure ratio across the cold side of the turbo... These two problems will be causing the turbo to have to work much harder to provide the same boost level.... I would not mind betting, that these restrictions are also causing quite high post turbo intake temps, which also will be robbing power and probably half the cause of the det when running higher boost on the dyno. (the other half being it not having anywhere near the right mapping yet)
Sort out the restrictions and I think this car will have a much flatter torque curve right away without loosing torque, just gaining more consistant torque and more BHP.
I have only just realised that Paul's car made its peak power at only 12.5 psi of boost.... Which for the current setup isnt at all bad and a good indicator for what the future may hold.
With intake manifolds, I do believe that the intake manifold on Paul's car is going to be a big restriction to power... but at the moment I think its not the biggest restriction by any means.
#210
indi9xx: Sounds like a great stategy should Paul elect to go that direction. So is Paul leaning more toward using a MAF or going to a full EMS? Anyway, I just sent you a PM too.
Cheers.
Cheers.
