Pressure washed engine - Now car sputtering and not boosting right? - Page 2 - Rennlist - Porsche Discussion Forums
Go Back  Rennlist - Porsche Discussion Forums > 924/944/951/968 Model Specific Technical Forums > 944 Turbo and Turbo-S Forum
Reload this Page >
Old 11-27-2006, 10:21 PM
smac951
smac951's Avatar
When I pressure wash, I use the distilled low pressure option. never had a problem.
smac951 is offline
Old 11-28-2006, 07:43 PM
Bill
I power wash my engine almost once a month when it is driven. This stumbling occurs every time after the power wash. I found what happens is water gets into the connections at the fuel injectors which causes the injectors to miss fire. To cure this, I keep a small can of WD-40 in my glove box. After a power wash, I pull each injector connection and spray the WD-40 liberally into the connector and injector. The oil removes the water thus preventing the miss fire. Plug the injector loom back in and the car will start and run with no problems. Guaranteed.
If water gets into the distributor cap, you will get a similar stumble. The WD-40, like above, can be sprayed into the cap to solve this problem. But the 944 distributor cap is sealed pretty well, so I have never had to spray WD-40 into it after a power wash.
Bill is offline
Old 11-28-2006, 08:20 PM
Keithr726
Super User
Keithr726's Avatar
Cool, thanks for the tip!
Keithr726 is offline
Quick Reply: Pressure washed engine - Now car sputtering and not boosting right?
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
