Interest in a “plug and play” EGT probe kit?
Old 10-24-2007, 09:10 AM
  #106
nick_968
nick_968's Avatar
I just bought Jim's EGT kit, did anyone make any progress with the 0-5V converter so I can wire this straight into my Motec?
Old 04-05-2008, 03:43 PM
  #107
Keithr726
Keithr726's Avatar
Laust! Put me down on the list for your next run of these. This is such a great idea and I just discovered the cap on my test tube was cracked and shooting exhaust junk allover the firewall. I guess that would explain the smell in the cabin under boost.
Old 04-05-2008, 04:05 PM
  #108
billthe3
billthe3's Avatar
With these things, is the voltage output of the sensor something that can be hooked up to an egt gauge or will the output only work for a datalogger setup?
Old 06-07-2008, 10:19 PM
  #109
Laust Pedersen
Laust Pedersen's Avatar
Default Not just play, but also plug
I finally managed to set some time aside to make parts for more EGT kits. I decided to keep the price unchanged (see post #1) in spite of parts cost increase. The installation instructions are still in post #65.
I am not quite finished yet, but am very sure everything is ready in 2 weeks (6-21-08).
There have been a few requests for a plug on the fitting in the X-over pipe for those who want to remove the test pipe or EGT probe. A number of people have successfully used a closed aluminum wheel lug nut, but aluminum having a melting point of 1220 F and non-sealing threads (straight, not conical) that practice is a bit questionable.
As a result I have come up with a solution, namely to use a solid double coned plug (“mini bowling pin”) together with my custom nut also used for the EGT kit (se the attached picture).
Whenever the EGT probe is installed the ferrule will be crimped on the probe and has to be ground off if you want to re-use the nut from the EGT kit as part of the plug. Therefore I am also selling the nut, ferrule and plug separately and the prices are $15 for the nut (a pain to make), $4 for the ferrule and also $4 for the plug with an S&H for any combination of the 3 components being $4 (domestic), $6 Canada and $8 ROW (no S&H addition if they are included in the EGT kit).
If you are interested in any of the above, just send me a PM in a week or so for payment details.
Laust
Old 06-07-2008, 10:35 PM
  #110
theedge
theedge's Avatar
Put me down for one. Is that a fairly fast acting probe?
  #111
Spidey944
Spidey944's Avatar
I am interested in the whole Enchilada still. Great job on the new bits!
Old 06-08-2008, 02:20 PM
  #112
Karbokane
Karbokane's Avatar
Im in for this round!
Old 06-09-2008, 01:36 PM
  #113
Laust Pedersen
Thanks for the interest.
"theedge", it is a fairly fast reacting probe, but as you can imagine the path through the headers (being heat capacitors) will slow down the registration of a rapid temperature change right out of the port.
Old 06-09-2008, 02:25 PM
  #114
User 41221
User 41221's Avatar
I have one and find it to be a useful overall indicator of EGT. Its not the same thing as having four (one in each header tube) but for the relative cost and ease of installation, its money WELL spent, imo. Laust should get a lot of credit for offering these, he's great to deal with and its a well done kit.
Regards,
Old 10-08-2008, 10:16 AM
  #115
Josh B
Josh B's Avatar
Hey Laust - are you still making these? Would be interested in one...
Old 10-08-2008, 10:42 AM
  #116
Spidey944
Spidey944's Avatar
PM's work best Josh, last I heard he had a set of 10 ready, but this was 6 months ago.
Old 10-18-2008, 10:50 AM
  #117
royj
royj's Avatar
Hello Laust,
I'm also interested by your EGT Prob Kit without gauge. I live in France. Could you confirm me the price and the shipping solutions, and how you want to be payed. Here is my e-mail adress :
jean.pierre.roy@libertysurf.fr
Thanks a lot. Best regards. Jean ROY.
Old 12-07-2008, 01:44 PM
  #118
Laust Pedersen
Default New batch
Well, a few Rennlisters have expressed interest in my EGT kits, so I finally managed to set some time (and money) aside to create another small batch.
Inflation has not yet reached my garage, so the price is unchanged, namely:
EGT Kit is $98 + S&H ($8 domestically, $12 Canada and $ 16 internationally)
Nut + ferrule or plug is $15 + $4 (+ S&H $4 domestically, $6 Canada and $8 internationally, if shipped separately from the kit)
If interested, just send me a PM to start the process.
Laust
Old 12-16-2008, 03:22 PM
  #119
Josh B
Josh B's Avatar
Order placed. Thanks!
Old 12-16-2008, 03:43 PM
  #120
gt37vgt
gt37vgt's Avatar
sorry I'm too lazy to read the intire thread is there any thing better than the tec edge 3e data logger?? O2 controller as it logs 4 thermocouples and some other stuff for 300$
Quick Reply: Interest in a “plug and play” EGT probe kit?
