951 Factory Headers vs. Aftermarket Headers
Ok...my second post this evening.
My exhaust header pipe is cracked, #3 to be exact. I am on the fence about having it welded, again or, purchasing one, such as the one that Speed Force Racing offers (Stage I).
I am interested in getting your thoughts on welding Porsche headers, or purchasing solid aftermarket solutions. I am fed up with having to get the headers welded every few years.
I have an 86 951 and have recently rebuilt the motor, chipped it, installed a 3" exhaust, etc.
Looking forward to the feedback.
zoso_turbo
zoso_turbo
Headers
There was a good article on the SFR header system in European Auto. It worked well and added some top end power on the dyno. Used stock units are probably available for much less. Depends on what you are looking for.
I'll do a google search and see if I can find it.
George
George
George
Thx for the assistance with locating this article....Is there any perspective on the SFR Stage I headers anywhere?? Not sure I can derive the value out of the Stage II system.
Thx again.
=dan=
Thx again.
=dan=
Headers
Dan,
If you can't derive value out of the SFR header system, then get a good stock unit. These aftermarket header systems, IMHO, are for the guys that are trying to get top high end power. Trust me, it's not much and you give up some bottom end.
Torque is what accellerates you, hp is what keeps you going. The stock headers were tuned for low end and good top end. They really are hard to beat. Maybe a good weld job will take care of things.
Food for thought.
George
Food for thought.
George
http://www.europeancarweb.com/projec...e_944_headers/
Quote "When the dyno testing was all said and done, Don was right about the top end--the headers lost a few horsepower with the factory turbo-back exhaust system retained. But, much to our surprise, the gains in the low end were substantial. Between 3000 to 4000 rpm, the car was able to maintain between 17 to 18 more whp than with the factory headers, indicating a tremendous jump in low- and midrange torque of about 30 lb-ft, thanks to the boost kicking in a little sooner. What this header system essentially did was shift the power curve slightly to the left, which is nice for tightly turned racetracks and autocrosses, where torque is crucial, or even around-town driveability. However, it isn't be what you want for high-speed, straight-line performance"
The SFR stage 1 headers look like a similar design to the B&B ones...
you shouldn't be welding headers every 2 yrs i tig'd mine up yrs ago and it didn't crack IMO the only headers to buy are equal lengths but they're crazy$ stage one's you might as well spend your money elsewhere and use stock headers
I'll weld your headers for you for $125, and you don't have to pay me until you receive them back and inspect my work.
2-3 is a common area to crack, the inner "Y" is problematic.
I weld them with a process I came up with a couple years back, using a spacer tube between 2-3 to stabilize the "Y", once you do that, no more cracks
I have pics of a repaired manifold I did on my other PC I will post them tommorow.
J
J
The crack is at or very near to the flange on #3...I will try and post a pic....
J....I am interested in getting you to weld the header...Can't say I have ever taken the headers off myself, can this be accomplished by an eager do it yourselfer?? Or should I have it removed by someone.
=dan=
=dan=
=dan=
=dan=
To be 100% honest Ive never taken JUST a manifold off a 951. Usually it was pull the motor then take the stuff off....
It should be 100% doable however.
Cracking at the flange is 100% normal on the "Y" pipe. Its prolly also stress fractured linearly along the pipe, but you can't see it. I'll inspect it carefully for you.
Lemme know what you wanna do, as I said 100% satisfaction guarantee
Jay
cracking at the flange is common that's where mine cracked remove the studs and nuts loosen 1&4 2-3 should slip out if so-cal can't help you i can, once you've done a few you know what to look for good luck
Basic Sponsor
Hey I found some oem headers with the updated accordian style join, they look great no cracks.
http://cgi.ebay.com/ebaymotors/ws/eB...ALCA%3AUS%3A11
Basic Sponsor
Originally Posted by 9fitty1
Lart where do you find these deals at? That is such a great price!
