Custom/DIY spark plug wire kits or sources? For wasted spark coilpacks.
Old 08-20-2006, 06:07 PM
  #31
theedge
theedge's Avatar
Originally Posted by OZ951
I use a Tec coil pack with stock Beru wires and connectors, they work fine and you can solve the seal or looseness by placing an appropriately sized electrical grommet over the post (ie it sits between the post and the boot of the plug wire). It's a $2 solution that works well.
Good point, ill see if I have correct sized grommets kicking around. Thanks for the idea!
Looks like you use Bosch ignitors there...?
Old 08-20-2006, 06:21 PM
  #32
OZ951
OZ951's Avatar
From memory the Haltech Ignitor is just a rebadged Bosch unit which I run with a 3.5ms coil charge time
Old 08-20-2006, 06:41 PM
  #33
theedge
theedge's Avatar
Hmmm 3.5 good to know. Mines at 3.0 right now, and itll jump the towers on the packs at 7000RPM
Have you ever measured the current theyre being charged to?
Old 08-20-2006, 07:14 PM
  #34
OZ951
OZ951's Avatar
No I havent, sorry.
Old 08-20-2006, 07:31 PM
  #35
theedge
theedge's Avatar
No I havent, sorry.
No worries, I was just curious. My setup is only capable of 6.5-7 amps per coil, and the XDI does them to 9 I think.
Quick Reply: Custom/DIY spark plug wire kits or sources? For wasted spark coilpacks.
