Stage 1 or 2 KEP PP
Stage 1 or 2 KEP PP
Finally getting around to ordering a KEP pressure plate.
Didn't realise there was a stage 1 and a stage 2 until now.
Which do I need? I'm probabaly between 350-400 rwhp.
Is the KEP Paragon Products lists a stage 1 or 2?
Basic Sponsor
Originally Posted by theedge
The KEP I got from Paragon was the Stage2, which I wanted anyway.
Originally Posted by lart951
I went to paragon's website and I can find the stage II
Basic Sponsor
Originally Posted by David Floyd
Lots of products they have are not on the website, stage 2 is $600 same as stage 1
If they dont have KEP1, they can order it or you can order it from from Kennedy Engineered Products. Its the same price.
Basic Sponsor
Less pedal force for all the lightweights out there
Special Tool said that a stage I with a copper ceramic clutch is good for 1000lbs of torque.
Basic Sponsor
And per KEP. the stage 1 and stock disc is rated at 600 ft lbs
Basic Sponsor
Originally Posted by jimbo1111
You don't.
Lart
So if the stage I is softer to the pedal and can handle 600lbs why would I need the stage II?
I bet that 600ft lbs on the stock disc is not after she heats up.
jwl is using a KEP stage 2 and 930 disc on his 2.8, no chatter and no slipping.
http://www.advancedclutch.com/provei...101-torque.asp
