Stage 1 or 2 KEP PP
Old 03-25-2006, 02:58 PM
jimbo1111
jimbo1111's Avatar
http://www.patrickmotorsports.com/cg...ES&cat2=&cat3=
I prefer someone who knows porsches. If you know what I mean.
Old 03-25-2006, 03:09 PM
lart951
Basic Sponsor
lart951's Avatar
Jimbo, sorry to bother you , but could you post or pm me the parts #'s for the plape and clutch.
TIA
Luis
Old 03-25-2006, 03:10 PM
David Floyd
David Floyd's Avatar
Originally Posted by lart951
So if the stage I is softer to the pedal and can handle 600lbs why would I need the stage II?
Let me say I wanted more clutch than I would need so Stage 2 and copper/ceramic 6 puck, because I went thru a period of clutch problems after my 2.8 build, the cup clutch lasted 1500 miles and I then went with a kevlar disc and cup pressure plate ( witch is nothing more than a stock pressure plate the disc makes the "cup" package ) that lasted 1500 miles also slipped like butter on the dyno, come to find out the pressure plate had a crack in it. Sooooo.... after 2 *&^%$#@$% clutch changes in a short period of time, no fun at all. I wanted to put an end to clutch issues.
I ended up with a combo that does not slip, is a on the agressive side but I do daily drive with no problems.
Old 03-25-2006, 03:12 PM
lart951
Basic Sponsor
lart951's Avatar
Okay, now you are talking my language. Is better to be safe than sorry, well stage II it is.
David, did you buy the puck ceramic bronze from paragon as well?
Old 03-25-2006, 03:15 PM
David Floyd
www.clutchnet.com
6 puck "Easy Lock Pro" spring centered I paid $200
Old 03-25-2006, 03:19 PM
lart951
Basic Sponsor
lart951's Avatar
www.clutchnet.com
Thanks David, is there any advantage in buying the one with springs over the solid one?
Old 03-25-2006, 04:37 PM
SoloRacer
SoloRacer's Avatar
lart: I think clutch engagement is the advantage of the sprung vs unsprung. With the sprung you can modulate the clutch with the pedal whereas with the unsprung it's more like an on/off switch. I would go sprung.
David: Does your clutch chatter?
Old 03-25-2006, 05:35 PM
TRP951
TRP951's Avatar
Im thinking of KEP stage 1 with a 930 disk for the street any opinions on this combo? I will be around 3-400 hp
Old 03-25-2006, 07:44 PM
David Floyd
Yes, take off at 1500 rpm or better to be smooth
Old 03-25-2006, 07:48 PM
lart951
Basic Sponsor
lart951's Avatar
So in a unsprung clutch you have to take off at even greater rpm's? is that what you are saying David?
Old 03-25-2006, 07:53 PM
David Floyd
I have never used an unsprung, so I can't say.
My sprung centered is smooth with 1500 rpm take off
Old 03-25-2006, 07:59 PM
lart951
Basic Sponsor
lart951's Avatar
Okay we need the input from a unsprung clutch user, jimbo? tool? anybody?
Old 03-26-2006, 12:05 AM
tconn
tconn's Avatar
Lart from my research a spring centered clutch is smoother than a solid disc.
I've decided to go with the KEP stage 2 PP. I'm leaning towards the bronze disc
but would like to hear from Jimbo or someone else how it works first.
How many of us are looking into getting a KEP PP? Group buy maybe?
Old 03-26-2006, 12:27 AM
SoloRacer
SoloRacer's Avatar
I would buy one if there was group buy.
Old 03-26-2006, 01:01 AM
lart951
Basic Sponsor
lart951's Avatar
Thanks I am also going for the sprung disc but i will go with the kep stg I PP , special tool told me that the stage II is too hard on the clutch master cylinder and could lead to the cyl failure.
Quick Reply: Stage 1 or 2 KEP PP
