*OFFICIAL* Griffin Radiator Group Buy - Friday March 17th Ending Date!
#331
Both of the sealing surfaces on mine looked flat and good enough for a seal. It also had a build sticker dated 7/18, so maybe they put in a little extra effort after some of the complaints started filtering in.
#332
That's Because I Have His Radiator..Received Two By Mistake..Returning 2nd Rad Friday
Originally Posted by nize
nope. buddy in seattle is still waiting for his.
#333
After installing my radiator, lower temp (83 deg) thermostat, and earlier start fan switch, I don't see much of an improvement from the stock set up I had. I had the lower degree thermostat and earlier starting fan switch with my older radiator. The needle still climbs to the top white line when idiling. It doesn't overheat, but the main reason I purchased this radiator was to drop my temperature down. Reno
#334
Same Here...No Real Difference..Probably Should Have Spent The $$$ On Other 951 Parts
#335
also, attempting to solve overheating problems by changing the thermostat is not the smartest way to do it, because what you're really doing is trying to 'cover up' the real problem, not fixing it. read here;
http://members.rennlist.com/951_racerx/Thermostat.html
#336
btw guys, according to griffin, we should have received the correct 10x1 metal drain plug WITH the radiator. i did not (and i'm assuming everyone else here did not as well). i'd call griffin and request that they send this asap.
also, i'm emailing griffin to explain all the crappy issues we've had with this group buy, and ask for a possible further discount/reimbursement, or some other sort of compensation. i'd recommend you all do the same, as they're more likely to listen to collective voices rather than a few.
#337
Originally Posted by jy951
BTW I got mine for 346.00 and it was perfect, and that was the shipped price, but I'm sure you'll find some bill of good tech to talk you out of more of your cash. lol
Did you ever get that smaller exhaust for your turbo car that increased torque?
#338
Originally Posted by ehall
leave it to you to waste cash as a result of your total auto ignorance. Well done.
You are CLUE-LESS, it's well known that PORSCHE and OTHER car manufacturers use the exhaust system to increase/decrease torque via the header and overall pipe (via mandrel bends) design. Only FOOLS LIKE YOURSELF GET ON RENNLIST AND ACT LIKE IT'S SOME SORT OF JOKE THAT EXHAUST DESIGN IMPACTS PERFORMANCE. Hey SMART-A$$, GO ASK THE PORSCHE FACTORY - THEY'VE BEEN TWEAKING EXHAUSTS (to INCREASE TORQUE, etc.) FOR YEARS TO IMPROVE PERFORMANCE - YOU ARE COMPLETE DUMB-A$$!!!!
#339
Really, I didn't get one... let me know what they say.
#340
Yeah, I never got the radiator plug, and I've even been having a hard time finding the correct one in town. I'll give Griffin a call today, and see where our radiator drain bolts are. Hopefully I can get them to send one out to everyone.
Matt
#341
Matt
Matt
#343
Originally Posted by Got Me a Porsha
Yes, Autozone stores stock them, as a HELP item, and about two bucks each.
griffin should send us the plug and the washer and whatever else they should have sent to begin with.
we should not have to go out of our way and pay more money to a third-party to complete their screw-up.
#344
#345
the point is, we already paid a couple of hundred bucks each for the radiator WITH the plug included, and did not get the plug.
While the latest run of Griffin's were not the prettiest of the radiator runs, they are very efficient and have dropped temperatures on our cars pretty significantly. They also installed easier then a stock radiator and I'm a bit more comfortable not having plastic nipples or threads. I guess I looked at it as I was interested in purchasing a part that has improved efficiency over the stock unit as opposed to buying art work.
Would I use griffin again? Probably not. Did it satisfy my need? Yes.
