GT vs Vitesse
Old 09-24-2006, 10:19 AM
  #166
333pg333
333pg333's Avatar
See, you can be sarcastic!
Old 09-24-2006, 10:38 AM
  #167
Guns951
Guns951's Avatar
Oh that's what that is? Hmmm. Didn't intend it that way...I was in a moment of amazement if you had been waiting. Plus I think we're the only two up at this hour.
Old 09-24-2006, 10:57 PM
  #168
RogueM3
RogueM3's Avatar
Originally Posted by Duke
Edman reports 20 psi @ 3200 prm, Markus 28 psi @ 3300 rpm both with GT30R.
From what I've read in your old posts your VT S3 has 15 psi @ 3300 RPM and 21 psi @ 3600+ RPM.
No one else harped upon this...can anyone else speak to this?
Originally Posted by special tool
Your car will be faster with a stage 2 at 10-11 psi than it will with a stage 3.
Speaking from experience.
The added spoolup and greater low-boost efficiency do a lot here.
Seriously? How can this be?
Old 09-24-2006, 11:13 PM
  #169
SoloRacer
SoloRacer's Avatar
Originally Posted by evil 944t
uh, more boost = more HP, last time I dyno'ed my car.
Todd, IMO, any time you add more boost your putting more stress on all the parts that have to contain the extra force.
Not true. You can get more power from a bigger turbo at lower boost than from a smaller turbo at higher boost. Think of it as a garden hose vs. a sewer pipe. One has high pressure but less volume. Volume of air is what gives you the power - not PSI. What we all want is tons of volume at the lowest possible pressure. The other thing to consider is where a turbo is efficient. You can't just keep increasing the boost and expect the car to make exponentially more power. At some point you will get to a boost level that is outside of the efficiency range of the turbo and you actually make less power.
Old 11-18-2006, 02:09 PM
  #170
333pg333
333pg333's Avatar
I like to bump this thread from time to time because:
a) wonder what happened to the kid??
b) wonder what happened to the Tial bolt on turbo???
c) there were some good things discussed here...
Old 02-27-2007, 06:18 AM
  #171
boerge
boerge's Avatar
Yes, having read through this tread I was wondering about the same.
What happened to the Tial turbo-kits?
Regards
Boerge
Old 02-27-2007, 07:12 AM
  #172
333pg333
333pg333's Avatar
Good luck on getting an answer on this question??? You're better off trying to find out about aliens.
Quick Reply: GT vs Vitesse
