Time to present the "GO BIG.."-project! With pics
Old 09-25-2008, 07:55 PM
  #481
mark_uss
mark_uss's Avatar
awsome car..keep up the good work...
Old 10-02-2008, 02:29 PM
  #482
Duke
Duke's Avatar
Car just got a new alignment and new R-spec tires, Bridgestone Potenza RE540S.
Ended up with -3.5 camber front -3.1 camber rear, neutral toe front and 0.30 deg total toe in rear.
A few new pics.
Old 10-02-2008, 02:39 PM
  #483
RolexNJ
RolexNJ's Avatar
Gustaf, is that a step-up 4 inch exhaust on the car? You may have said it in the previous pages but I didn't look.
Old 10-02-2008, 02:46 PM
  #484
Duke
Duke's Avatar
It's a 4" exhaust, but unlike the "standard" 4" exhausts available this one transitions to 4" directly behind the starter before the wastegate is tied in. Minimum backpressure
Old 10-02-2008, 03:20 PM
  #485
porshhhh951
Monkeys Removed by Request
porshhhh951's Avatar
WOW the second shot is breathtaking.
any chance you could email me a high res version?
Old 10-02-2008, 07:13 PM
  #486
Duke
Duke's Avatar
Thanks,
PM me your address and I'll send you a high res version
Old 10-02-2008, 07:29 PM
  #487
porshhhh951
Originally Posted by Duke
Thanks,
on the way.
Old 10-02-2008, 07:33 PM
  #488
gt37vgt
gt37vgt's Avatar
hahah "standard 4" cool well i think yours is standard as thats how i've done mine but I'm back as far as the rear cross member scratching my head for clearance .
Old 10-02-2008, 07:46 PM
  #489
Voith
Voith's Avatar
I'd love big res second photo too :P
Old 10-02-2008, 08:15 PM
  #490
RolexNJ
RolexNJ's Avatar
Have you guys had them on 951s before with any test results? I am just curious if you have any data.
Old 10-02-2008, 08:29 PM
  #491
333pg333
333pg333's Avatar
You can always get more clearance if you go to ovalized pipe.
Better clearance next to a standard round 3" system. Going to 5" out...
Old 10-03-2008, 05:55 AM
  #492
Duke
Duke's Avatar
hehe yeah ground clearance isn't the best.. it can be seen on the last pic. But that equalls my front lip ground clearance so any bump will hit there first.
This height is perfect, I can actually go over any speed bumps in my area without contact.
Old 10-03-2008, 05:59 AM
  #493
Duke
Duke's Avatar
that's a really nice system. But ground clearance is overrated for those of us using a front lip. Just take a look at the front pic I posted. As long as that ground clearance is lower than the exhaust then the exhaust clerance is the least of your problems.
I uploaded a high res pic for anyone else that wanted:
http://www.revline.se/cars/RRXXX/200..._1_HIGHRES.jpg
Old 10-03-2008, 06:16 AM
  #494
gt37vgt
gt37vgt's Avatar
yeh i think I'l just squeeze it down a bit to 3" high oval but I am making my own rear cross member later with better geometry and better clearance
Old 10-03-2008, 07:59 AM
  #495
333pg333
333pg333's Avatar
...respect...
Quick Reply: Time to present the "GO BIG.."-project! With pics
