Time to present the "GO BIG.."-project! With pics
#346
Rocket Scientist
That end is priceless! LOL. Rock on, Duke.
Mine will soon follow. Not that you haven't heard it before, but I'm a rare color fanatic, that green looks rad.
#350
Thanks guys, a lot of time invested
The engine mods were requested in another thread, here's the list...
I think this is the full spec's for the engine and related:
Shortblock:
Removed balance shafts
Grouted block
Raceware rod bolts&nuts
Raceware head bolts&nuts
All new sensors
All new water hoses
Broadfoot AC delete
Cometic Phuzion MLS headgasket with gas filled rings
Block honed, machined and decked.
Balanced crank & pullies
Head & valvetrain:
High velocity ported and decked head
Valve seats worked
Lindsey Racing valvesprings, custom spring rates
Intake and intercooling:
Stock intake manifold - will be replaced soon
Custom 2.5" intercooler pipes
450x300x100 mm intercooler
Tial 50mm BOV
Exhaust manifold & Exhaust system:
Modified crossover
Custom 4" exhaust. 3" downpipe and 2" wastegate merges together and transitions into 4" (NOT FINISHED)
Magnaflow muffler
Turbo & Wastegate:
Garrett GT3582R, 0.82 a/r
4" turbo intake pipe
Tial 44mm v-band wastegate
Engine management system & Ignition:
DTA Fast E48Exp
MSD coil pack, wasted spark
Magnecor KV100 ignition leads
NGK Race spark plugs
Full custom engine and EMS harness
Fuelling:
Bosch Motorsport 044 fuel pump
Delphi 998 cc injectors
Lindsey Racing fuelrail
Lindsey Racing braided fuel lines
Fuel Lab adjustable fuel pressure regulator
Marren fuel damper
Oil management:
Anodized sandwhich plate with AN fittings and temp/pressure ports
RX7 FC large oil cooler, 10AN Push-on hoses
GReddy oil catch can
Drivetrain:
Spec stage 3 lightweight clutch
Spec aluminum lightweight flywheel (balanced with engine internals)
Gagues and control:
PLX R-500 wideband, EGT and knock controller
GReddy Profec B Spec II (EBC)
GReddy Turbo Timer
Autometer Fuel Pressure Gauge
Autometer 60mm boost gauge
Autometer 52mm Oil pressure gauge
Autometer 52mm Oil temp gauge
Shortblock:
Grouted block
All new sensors
All new water hoses
Broadfoot AC delete
Head & valvetrain:
Valve seats worked
Tial 50mm BOV
Modified crossover
Magnaflow muffler
Turbo & Wastegate:
DTA Fast E48Exp
Fuelling:
Marren fuel damper
Oil management:
Drivetrain:
Gagues and control:
GReddy Turbo Timer
#353
Alright the first test drive is completed...
Remember that this car hasn't been on the road since October 2005!
The whole chassis, brake system and engine is completely new and most of it is custom specs..
The suspension feel amazing, rock solid and very tight and surprisingly smooth on harsh roads.
The engine runs very smooth and revs extremely fast compared to a stock 951. Lightweight clutch, balanced Fidanza flywheel, removed balance shafts, balanced internals etc. has paid off!
The engine is running just a rough base tune but there were no problem lighting up the 285's in second gear already at 12 psi
There's still a lot of work before it's really driveable on regular roads, but we're getting there.
#354
Gustaf,
sounds good. my project will hit the streets next spring
Too much work with new house etc. Also lack of funds is a restricted factor, if you build it as it should.
#355
I know what you mean all to well Olli! Amazing how long time these kind of projects can take when you have so much else to take care of.
How's the house build coming along?
#357
it looks a little bit different what it was when you last time saw it. It's ready and we moved in last November. Also garage is more or less ready. Lots of work to do outside. Garden is still at the starting point. The whole area is one big construction area, currently almost 100 houses are in the middle of building process.
