Requesting pics of RX7 oil cooler installs
The threads about this all have no pics/dead links to pics. I want to upgrade mine before I start racing. I also want it so I can get rid of the stock one, and put this in its place...
Love the remote oil filter. How do you tie this setup into the block?
Also, any reason you can't go with some cheap & huge GM filter as long as you're going remote? I don't see any advantage to the Mahle filter if you're no longer mounting it inverted, plus there's gotta be cheaper GM remote filter kits.
Thanks for the pics shortyboy!
Its a MOCAL from www.batinc.net where I also got the takeoff plate. It the takeoff) is kinda pricey at $60USD or so, but thats because it rotates so itll point anywhere. The remote filter mount is $40, but theres cheaper ones. Its impossible to find remote mounts that use the 944 oil filter thread and size, the one I got uses whatever size VWs use (as well as tons of other makes). Funny thing is, the 944 filter seems to thread on just fine and will torque down, so its great for testing purposes Ill just start getting Mahle filters in the VW size from my mechanic. Mahles are a great filter anyway, so no point in downgrading to something cheaper just to save a few bucks.
huh, that's pretty cool...and well worth the $60 in my opinion. So guessing from the pics, it just screws into where the oil filter would go?
btw, I hope that's just a temp solution for a turbo water block-off plate
Must be temp, no hose clamp on the lower rad hose :P
Amsoil's kit should fit our oil filter mounts, no?...
Then you could mount a dual remote bypass setup, and run any of their filters with a check valve, along with having bypass filtration.
That's a cool idea for the oil cooler (hahaha), have a lot of people done this mod? How hard is it to do?
I'm going to relocate my oil filter, and the current oil cooler position is looking mighty handy, so if there's a setup to relocate the oil cooler out front.....
More than 60. Im at about $120USD total I think, after the take off, mount, fittings, etc.
I still have to figure out the hoses and such. Right now, the hoses could be 5 inches long and straight, but that wont have enough flex I dont think. I think having 45 degree ones on the take off will let me do a loop of hose.
I have to trade in the push lock fittings (had a HUGE brainfart when I ordered ) and get the normal AN fittings, since I already have the hose.
Originally Posted by J Chen
Don't forget to remove the thermo in
the RX oil cooler & block up the hole.
