CLICKING NOISE AT ENGINE START!!!
I turn the car in the morning when i go to work and i hear a clicking or maybe i would say a tapping noise maybe caused by rubber...
Any ideas what it could be???
I also have an occasional problem that the car stalls when turning the key...
What can i do???
Thanks..
What can i do???
Thanks..
I never notice, anyway
if it's right away at startup, most likely its the lifters. mine do that. when they get older, they dont hold oil as well and the oil will drip outta then when not running.
i don't even know if i have ABS Brakes....
it only happens when i first start the car in the morning....
I thought it was the belts....if it is the belts.... should i be worried???
so it may be the filter...(what filter do you people recommend)
Mexican Ambassador
demon, i'm 90% sure it's the lifters. if it's first thing in the morning, and never happens again all day, then it's that, since the oil drops back down when the car's not in use. ever seen that "oil starvation" castrol commercial? i assume it's just gonna happen. i dont think the lifters get damaged, do they?
I used to have slightly noisy lifters and then I put some marvel mystery oil in the red container....no more noise. Now I also had this problem on a POS car I did not really like, and I found having the right amount of oil in there helped
