FS: Cup One Wheels (911 Turbo)
Originally Posted by georgeleroy
Ok, so the bolt pattern fits an 86, and the style looks great, how wide of a spacer will work before you run out of studs? Can you get the tire to fill out the fender without replacing the bolts?
1) replace all the studs (fronts need about 65mm & rear 68-72mm IIRC but don't quote me) get open ended steel lug nuts to use your early offset wheels-$27 set from someone on the rennlist classifieds
2) install spacers with the studs included--price goes way up but usually includes everything
the cheapest way is to get porsche oem 21mm front & 28mm rear although some machining is required to fit the 21mm to the front so it will clear the small center hub cover (originally made to fit 911 turbo rear).
check out danno's racer x site (always forget wht the hell that site is called & it doesn't come up on google--ask someone on this thread) or danno might chime in. he's always gone out of his way to make his knowledge available to people on rennlist--he's one of the few people who actually answers the whole question.
happy spacing!
