Too much hp-talk, let's talk real life numbers!
Old 10-13-2005, 03:06 PM
  #46
95Juan
Mexican Ambassador
95Juan's Avatar
Originally Posted by Markus951
I will wideotape mine in abandond airfield. put the wid up from 0-200 etc. 100-200 with 3rd and 4th gear.
Markus
cant wait. i wanna see this one and compare it to ST's.....we NEED MORE VIDEOS.
Old 10-13-2005, 05:30 PM
  #47
Tomas L
Tomas L's Avatar
Below 9.5s
15°C or maybe a little below.
265/40-17, 235/45-17 although I don't see how that would make any difference.
1.25 bar and falling with rpm.
Stock K26/8
Captured with LM-1 datalogging (don't trust speedos, mine showed 220 km/h when the LM-1 showed rpm coinciding with 200 km/h).
Tomas
BTW. Many posts, few numbers.
Old 10-13-2005, 08:25 PM
  #48
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
100kpr-200kpr done in 13.67s
Outside Temp: 41C
Humidity: 91%
Tires:
Front 205/55/16
Rear 225/50/16
Tire Pressure: 32psi all four (factory recommended 36psi)
Fuel Tank: Full
Measuring Device: Hand held GPS (Garmin) for speed/Stopwatch for time
Car was fully stock, will do some runs in the next few days and compare
Old 10-14-2005, 06:05 AM
  #49
Duke
Duke's Avatar
Not bad for a stock car Hos.
Phew 41C! I feel sorry for your intercooler..
Old 10-14-2005, 06:23 AM
  #50
hosrom_951
hosrom_951's Avatar
By the way, that test was done in summer 2004 (early August to be exact), and carried out at night as well.
That is one of the many reasons why i don't go on full boost during the day at all in summer season, winter is very forgiving with a 25C high during the day and 10C during the night (what do you expect from a desert?).
Old 10-14-2005, 10:24 AM
  #51
toddk911
Drive-by provocation guy
toddk911's Avatar
I always thought the 60-100mph 3rd gear test was the best.
Old 10-14-2005, 02:44 PM
  #52
Black Arrow
Black Arrow's Avatar
100kpr-200kpr in 4th gear, 10.6 sec
100kpr-200kpr with both 3th and 4th gear, 8.5 sec
Outside Temp: 15C
Tires:
Front 225/45/17"
Rear 255/40/17"
18psi
1500kg car + 55kg girlfriend
1/2 tank
For any reason the AF wasnt perfect during the run. Will check this more tomorrow.
After the run I catched up a Mercedes AMG, but he didnt want to join me when I putted the throttle to the bottom!
Old 10-14-2005, 07:36 PM
  #53
Tomas L
Tomas L's Avatar
Please post what measuring method you use.
Old 10-14-2005, 08:31 PM
  #54
Black Arrow
I used the km/h @ the blitz power meter. This is tuned with a GPS so it shows pretty exact numbers I changed the boost down a bit cause the AF, but I could be pending between 18/19psi.
The VR stage 3 is strong! You should know by now
Old 10-15-2005, 06:54 AM
  #55
schnellfahrer
schnellfahrer's Avatar
Thomas, please tell me where the hell you found a stretch to do this test without fear of 6months in prison and 2 years as a pedestrian.
No way Siv is 55kg. More like 39kg
Old 10-15-2005, 07:07 AM
  #56
Duke
Duke's Avatar
Thought I'd add details about my run.
100-200 kph: 8.9 sec (using 2nd, 3rd and 4th gear)
Outside temp: 13 C
Tires: 235/45-17 front, 255/40-17 rear
Full weight car, 1/3 tank, 2 persons.
Turbo: the underrated K27/8
Old 10-15-2005, 08:11 AM
  #57
hosrom_951
hosrom_951's Avatar
Editied my post....
Old 10-15-2005, 08:40 AM
  #58
special tool
special tool's Avatar
"No way Siv is 55kg. More like 39kg"
Dude - buy her a sandwhich!!!!
Old 10-16-2005, 07:47 AM
  #59
Luis de Prat
Luis de Prat's Avatar
He was in Spain on vacation!
I should've timed my Cab two weekends ago when I went chasing some 911s at highways speeds. With the top down, acceleration was probably shot to he##, but it sure was fun!
Old 10-16-2005, 02:49 PM
  #60
TurboTommy
TurboTommy's Avatar
Accelerated through 100 kph, started clock, 3rd and 4th gear, stopped clock at 200 kph, accurate speedo (minor issue, anyway)
between 7 and 7.5 sec; made two passes which were close to the same time
9 degrees C.
3000 lb. includes half tank gas plus two occupants
tire size does not matter
PUMP GAS
top speed: 300 kph
As already stated, heads up comparo is probably best. But, this is better than 1/4 mile and dyno.
Quick Reply: Too much hp-talk, let's talk real life numbers!
