Too much hp-talk, let's talk real life numbers!
#241
Originally Posted by Skunk Workz
So upping boost from 18 to 24 psi gives no power...damn....
VE is about how much you cram in the cylinder each time,and keep there. Increase boost,and the VE will increase. Now,if we're talking of if this is an effective way of increasing VE...I don't think so. It's always better to make a very efficient engine (high NA VE engine) and then boost it than "just cranking up the boost".:
I like the second definition much better and uses it whenever I talk about VE. It tells me more about the engine.
Something tells me that you already knew all of this...
#245
Drive-by provocation guy
" So upping boost from 18 to 24 psi gives no power"
He was refering to the homebrew and/or running higher octane does not give more power.
Turning the boost up does, assuming you have not readed the turbo's inneffeciancy range and are jsut making more heat.
#246
If Tool makes a decent brew,it should have hypersonic burn speed making him able to run 1.2 degrees of ignition at 6K rpm thereby reducing losses.
#248
Originally Posted by special tool
Boy - that's funny how you mention 2 strokes for testing aromatic fuels.
I know a guy who does that.
Bring the alcohol carb....Ima kicka you ***
#250
hahaha - watchoo know about an H2?????
#254
In all seriousness - I do have a special fuel that I mix just for the 951 and I am happy with it now and use it consistantly.
It performed better in the 951 than the VP race fuels.
It consists of a few different things.
