Feeler: SFR Fuel injector harness GB
Old 08-18-2005, 12:22 AM
TRWright
TRWright's Avatar
Default Feeler: SFR Fuel injector harness GB
This is a feeler for a group buy on a replacement fuel injector harness. Tim at SFR (Rennlist Sponsor) will be making these for us at an unbeatable price. $119 will be the cost, and I have been promised that they will be WAY better quality than the others out there. They can also be made in a few different colors. For those of you that want to know why you should replace your harness, check out the pic I supplied. If anyone needs any more information, please post up your question in this thread. This is a feeler thread to see if we can get enough people to make this happen. (Which shouldn't be a problem!)
Originally Posted by MPD47
Basically, pull the little rubber boot back, that'll be your first indication. It's entirely likely there are other places in the harness that are cracked/falling apart too. Chris White explained this in depth to me earlier, about how they wires sit fairly stationary over most of the life of the car and when we move them they crack and fall apart rather than flex like they should.
Here is a pic of MPD47's harness. I checked one of mine by cutting the rubber shroud off, and one of the wires was bare in a spot. I have not had any problems with it yet, but I see how this could cause an issue!
TRWright is offline
Old 08-18-2005, 12:24 AM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
Count me in, i am not going to sit and wait for one (or more) injector wires to go bad.
hosrom_951 is offline
Old 08-18-2005, 12:51 AM
streckfu's
streckfu's's Avatar
I'm interested.
streckfu's is offline
Old 08-18-2005, 12:55 AM
Andial951
Legend Killer
Andial951's Avatar
How does the SFR harness compare to the new Lindsey?
Andial951 is offline
Old 08-18-2005, 01:03 AM
TRWright
TRWright's Avatar
As far as price? LR sells theirs for $159 I believe. As far as quality? I have not seen either harness, but I am told that the SFR will be better then LR's because of something Tim does to prevent the ends from fraying. I am sure he will chime in with a more technical answer.
TRWright is offline
Old 08-18-2005, 01:38 AM
Jakerx
Hitsquad Ninja
Jakerx's Avatar
sweet. let me know. my harnesses are $hit.
Jakerx is offline
Old 08-18-2005, 03:19 AM
NZ951
NZ951's Avatar
Good work Teddy and SFR... great price!
NZ951 is offline
Old 08-18-2005, 04:27 AM
ehall
ehall's Avatar
IN! I AM! need to know about colors once you find out.
ehall is offline
Old 08-18-2005, 11:25 AM
Red1
Red1's Avatar
Put me down for a set.
Red1 is offline
Old 08-18-2005, 11:59 AM
MPD47
The Carnage King
MPD47's Avatar
Guys I HIGHLY recommened this to EVERYONE. This caused me to burn out a brand new set of 72# Siemens injectors and have various other issues on my car. If you arent going to replace the entire harness (because well, most arent as bad as mine was) I suggest this as a bare minimum maintenance item! (Like new fuel hoses, though honestly I think the Lindsey Rail is your best bet).
MPD47 is offline
Old 08-18-2005, 12:08 PM
Jon Moeller
Jon Moeller's Avatar
Were these available before Lindsey's harnesses? I didn't realize that SFR made these harnesses until this post. How are they better than Lindsey's units?
Thanks,
Jon
Jon Moeller is offline
Old 08-18-2005, 12:20 PM
pk951
pk951's Avatar
Same question here how are these better than Lindsey's, great price thou. Let's see some pictures, more info?
pk951 is offline
Old 08-18-2005, 12:45 PM
Red1
Red1's Avatar
How soon could this happen? I'd take these as quick as Tim could ship them.
Hmm. Been wanting to buy a test pipe from Tim anyway. Might as well make a big box of it.
Red1 is offline
Old 08-18-2005, 12:57 PM
WesM951
WesM951's Avatar
Depends on when this is to take place, but I am most likely in.
WesM951 is offline
Old 08-18-2005, 01:53 PM
rhesus
rhesus's Avatar
Ditto
rhesus is offline
Quick Reply: Feeler: SFR Fuel injector harness GB
