Rennlist Top 10 HP/TQ
Old 07-29-2005, 02:11 PM
Jake951
Jake951's Avatar
John (porshhhh951) - Your dyno plots look amazingly similar to mine! Are you sure you don't have a K26/8 in your car??
Old 07-29-2005, 04:44 PM
NZ951
NZ951's Avatar
Originally Posted by OriginalSterm
should it be specified what kind of dyno the numbers come from? are dyno sheets required for proof, or are we on the honor system?
Maybe the numbers should specify the dyno, but I dont want to create another category, so where possible I will put a note next the the numbers. I will ask for a dyno sheet where I feel it necessary...
Old 07-29-2005, 04:48 PM
NZ951
NZ951's Avatar
Originally Posted by fast951
Peak numbers are fine, however the actual power curve is more important. The type of dyno used is a must, as load dyno (such as Mustang) reads lower than a DynoJet.
You are very correct about the curve, hence why I thought about adding HP and TQ then dividing by when peak TQ is realised to get a ratio. I will be adding the dyno used where possible.
Old 07-29-2005, 04:52 PM
special tool
special tool's Avatar
A lttle birdie told me about a guy with a higher 2.5 than mine - let's see if he posts - if he isn't UNDER too much PRESSURE.....
Old 07-29-2005, 05:08 PM
Andy
Andy's Avatar
I better get in while I'm still on the list. My bests (from 2 different runs, dynojet) were 282 hp and 308 ft-lbs. Thanks.
Andy
Old 07-29-2005, 05:13 PM
streckfu's
streckfu's's Avatar
Mines pretty modest at 240/276. This is with the stock WG.
Old 07-29-2005, 05:22 PM
MPD47
The Carnage King
MPD47's Avatar
This one?
Old 07-29-2005, 05:51 PM
reno808
reno808's Avatar
Here is mine hope it makes it to the list.
Old 07-29-2005, 07:00 PM
special tool
MPD - yes. That thing probably makes a little bit of power.
Old 07-29-2005, 07:13 PM
rage2
rage2's Avatar
2.5L - 461WHP(6500)/401WTQ(5700)
2.8L - 412WHP(6400)/372WTQ(5600)
dynojet numbers
Old 07-29-2005, 07:19 PM
fast951
fast951's Avatar
OT - Any idea where to get the lhood louvers from?
John
Email
www.vitesseracing.com
Old 07-29-2005, 07:22 PM
NZ951
NZ951's Avatar
They look like the ones marketed by that 928 Performance place.
Old 07-30-2005, 12:02 AM
Chris Prack
Chris Prack's Avatar
OK I know it's not "mine" but I did build it!! My buddy Dennis's 88 951 is up there...
Notice the curve......
Old 07-30-2005, 12:31 AM
NZ951
NZ951's Avatar
Chris, does he have a Rennlist name?
Old 07-30-2005, 02:09 AM
porshhhh951
Monkeys Removed by Request
porshhhh951's Avatar
been debated to death...no I dont.
Quick Reply: Rennlist Top 10 HP/TQ
