Laust Pedersen's vacum adaptor?
Old 07-16-2005, 08:20 PM
renvagn
renvagn's Avatar
Default Laust Pedersen's vacum adaptor?
Hi,
Previously I saw a thread about a custom made adaptor which replaces the old daisy wheel with 4 vac lines going into it, then going into the intake manifold. I can't find the thread after an hour of searching. Also, for a 951 S with two banjo bolts going into the intake, wouldn't I want the adaptor with the two holes and 4 fittings, compared to the one hole and 5 fittings?
Old 07-16-2005, 09:13 PM
Sam Lin
Sam Lin's Avatar
https://rennlist.com/forums/showthre...acuum+manifold
Sam
Old 07-16-2005, 11:05 PM
Laust Pedersen
Laust Pedersen's Avatar
Renvagn, You are right, since you didn’t provide specific information with your check and since I couldn’t correlate your Rennlist name to your actual name, I took a chance and guessed (wrongly) that you wanted/needed the most popular version.
Also I do not make a 2-banjo bolt 4-port version (only a 2-banjo bolt 5-port version), since there did not seem to be a demand for it. The 5th port can easily be plugged or can be used aftermarket items such as vacuum gauge, pressure switch for water injection etc.
I will be more than happy to swap the one you got for the one you need. Just let me know via PM or regular email.
Laust
PS Thanks Sam
Old 07-17-2005, 09:25 AM
ehall
ehall's Avatar
OT" Laust, did you have too send your intake manifold too the company, too have then clolor coat it for you, or did you order the product and apply it yourself? How has it worn?
Quick Reply: Laust Pedersen's vacum adaptor?
