FOUND turbo knowledge! (is this the right turbo?)
#181
Campeck Rulez
OOOO! you were talking about the rear turbo setup!!! WHEW.
i thought you mispelled s"D"s and I was going to have to go find a better standalone.
yeah...that rear turbo setup might work on a drag car with a HUGE V-8 but for a 4banger street car looking for fast spool and whatnot...ah-uh.
#182
Forget a rear turbo setup. I still cant figure out who thought that was a good idea in the first place. i guess it is simple enough, but a V8 on engine alone is torquey especially a 350 or 383 chevy. I was debating with a couple of guys on the 928 forum that want to do a similar rear setup. To me its just a waste of $, and on a 4cyl you would have a lot of laaaaaaaaaaagggggg.
#183
Originally Posted by J Chen
Hey Shortyboy,
We're running the same set up. BTW, does the oil cooler
feels warm or hot ?
feels warm or hot ?
#184
btw,that rear turbo setup is a great idea BUT i think with all that piping that there would be alot of lag,plus all the weight from the long piping.great idea tho.just image someone rear ended you.
#187
Hi Shortyboy,
Yes, I'm running AC. No hot running issues. Got a Supra
IC but will install it after final tuning. Will move the oil
cooler up to where the stock IC is when I go front mounted.
The horrible part about using the RX7 oil cooler was the need
to fill up 10 litres of oil.
#188
Campeck Rulez
