Lindsey Racing 3.0L 8V - Dyno Results
#286
Can ANYWAY explain why it says FLYWHEEL on the chart? And why these magic 55lb injectors can flow twice the amount of fuel every other 55lb injector is capable of? And how you get over 80 more WHP by adding race fuel and NO other changes? Just smells ummm fishey...
#287
Basic Sponsor
Originally Posted by RolexNJ
Power is the same? Humm. 472 RWHP vs 540 RWHP? Sounds the same to me.
#288
Ok you got it, it's all a lie - total lie, you win, "game over".
I am done here............
1.) Lindsey Racing - 877.943.3565 (ask for Mike or Dave)
2.) Power -Tech - 973.586.3210 (ask for Brian, he did the runs)
#289
Basic Sponsor
Sorry you dont believe with all the data I have presented too. So, I "STRONGLY" suggest you call both companies below, but, that still won't be enough for you I'm sure - and that I will bet on. That being said, ya know what NZ, I give up here totally.
#290
#291
It just does not add up. It's not that you can't make that kind of power, you just cannot do it with 55lb./hr. injectors unless you have 8 of them and then they still need to flow 54lbs./hr. at 55 psi driven @ 80% duty cycle. That is a LOT of fuel. You would need two of their fuel rails and a high volume pump like a Weldon to get the fuel up to pressure.
#292
UAE Rennlist Ambassador
Holy crap Rob!!
that is 630+hp at the flywheel! with a pegging MAF and 55lbs INJECTORS?? so there is still power left on the table!!
awsome work !!!!
awsome work !!!!
#294
Basic Sponsor
Originally Posted by hosrom_951
Holy crap Rob!!
awsome work !!!!
awsome work !!!!
#296
Originally Posted by lart951
How do you figure 630hp? is that arabian math Hussam?
#297
Basic Sponsor
Its easy! You take the actual HP of 465WHP, using a negative exponential multipler of 20, and subtract humidity, then inverse the demoninator, then using the Polar heuristic take the last decimal factorial, then you get 620BS-WHP.
#298
Originally Posted by ehall
lol. If Timexnj's brakes work as well as his injectors, then he'd better not lock em up, or Horseram will end up so far up his *** that Timex will wonder if NASA shot him from Cape Kennedy. Now that'll be a dyno chart!
#299
Basic Sponsor
#300
You guys are killing me ........
