before I pull the trigger, I just want to double check...
996 turbo twist hollow spoke do fit in my 88 turbo(non s)
would I have any problems without roled fenders, or should I get them rolled?
any rubbing issues?
should I change the tire size?
what tire size is recomended?
regards
chris
any rubbing issues?
regards
chris
chris
there are 2 different rear wheel offsets for the 18s, nb and s
the nb offsets should fit if your cars offsets are like my 89
do a search on the 993 or wheel tire forums
but i wouldnt do it, 17s, yes
thankx steve for the info. My offsets should be the same as yours.What is "nb" and "s" im assuming the "s" is for type s right?
thankx chris
thankx chris
"I have heard the 11" rears will not fit our cars."
They would fit on an '86 because you can juggle spacers to center the rim. The trick is to center the rim between the outer and inner interference points. On my '86, I've got 17x11.5" wheels with 275mm tyres and they only rub at close to full suspension travel, on both the outside and inside at the same time. The rear wheel with the 65mm offset is what you want. Haven't seen anyone try this wheel on the late-offset '87+ cars yet.
just bought them, Im going to have the body shop roll the hell out of my fenders....Im going todomy damn best to get them to fit, wish me luck!!! I dont think they will fit tho, but you will never know until you try. worst case scenario I will just sell them to a good home. I dont know what Im getting into buying this car, but like anycar I had its a learning curve.
thankx again for everybody's help
chris
chris
