piston ring material
Can anybody confirm the stock piston ring material? I have a set of rings (2 actually) from Goetze and I can't tell if the top ring is chrome plated or not. I did a search and saw that chrome should be avoided with an Alusil block.
What is the ring material, and what is the coating?
TIA
TIA
I have a set of goetze rings beside me, and it does look like the top ring is chrome plated, but I am reasonably confident that goetze wouldn't do something that thoughtless.
Perhaps somebody knows for certain, since now I want to know as well, just for peace of mind.
the Mahle catalog states
top ring: "R 1.75 IF Cr P"
where...
R = Rectangular faced
in mm
IF = Internal bevel (top)
Cr P = Chrome plated Phosphate
2nd ring: "D 2 IF Cr P"
where...
D = (Dachfasen...or angled) Taper-faced,
in mm
bottom ring: "DSF 3 Cr"
where...
(Dachfasen Mit Schlauchfeder...or angled with spring)
in mm
Cr = Chrome plated
Kolbenschmidt reference states: Use of Cr-coated rings are "not possible" only with Nikasil, Galnikal or Chrome composite cylinders
and says Cr-coated rings are used with Alusil and Silumal composite cylinders
check out:
http://www.msi-motor-service.com/ks/en/main/index.asp
for lots of good info
(and maybe find that other post and reference this one)
