Vitesse
#31
Originally Posted by shaheed
with the reliaboost i had to run the dual port wastegate in single port mode and it would drop off a little bit in the upper rpms (although not as much as it dropped off with an mbc+stock turbo). with the ebc it holds whatever i want to redline...
#32
Originally Posted by danny951
Did you have the CV bypassed/deleted with the single port setup?
#34
Chen - no, they are the same. Repeated through many tests
Also - tested with a real wastegate.
If you knew how many 951 datalogs I have made, it would make your head spin.
