Pics of my new Bursch test pipe. Where do I put the bung?
I finally snapped a few pics of my new test pipe with a friends camera. I tried searching for info on where the bung should be welded on but the pics I saw were not very clear. None of them were a birds eye view. I saw some on the curves but I didnt know which curve it went on where it would fit the best w/o hitting anything. Can someone circle the spot where it should go? I know that the sensor should be in the 9-3 o'clock range also. Here are the pics:
Anywhere in this area, mount it 90° to the pipe, a little higher up is better and make sure that you are able to change the sensor. TEST fit, hold the sensor there, make a mark.
Originally Posted by Oddjob
What sensor do you want to install on your test pipe?
https://rennlist.com/forums/showpost...&postcount=205
That should help. I gave the exhaust shop that pic and they put mine on for me.
Thanks for the help guys. I think I'll go and take a look under there with the cat on and then just make the mark on the test pipe, since the routing is the same, right?
