HOLY SH#@!&*@T Vitesse stage 3 spoolup
Old 02-12-2005, 02:10 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
Joe: Thing is, i was mis-informed on the length/width needed to wrap the exhaust x-over pipe (was told 1" x 50' was enough for that job).
But Paul (944 Fanatic) started a thread regarding some work of his, he used the 2" type and also confirmed to me that the 1" wrap would need to be at least 100' not 50'.......ordered 2 rolls of 2" x 50' but only used one for the x-pipe while replacing the oil sump gasket.....
So i ended up with a new roll (still packed) of 1" x 50'.......maybe use it for my 3" velocity down......
never mind !!!
Old 02-12-2005, 02:14 PM
special tool
special tool's Avatar
boostguy - 12
Old 02-12-2005, 02:16 PM
special tool
Hosrom - you are right. You will need at least 100 square inches to do headers and crossover.
NZ - no cracks about the English system.
Old 02-12-2005, 02:20 PM
BoostGuy951
BoostGuy951's Avatar
Wow! Are you planning on leaving it that way or leaning it out a bit? Those are damn good numbers on the spool!
Old 02-12-2005, 03:48 PM
MPD47
The Carnage King
MPD47's Avatar
Hmmmm, very nice! Cant wait to drive mine.
Old 02-12-2005, 04:40 PM
FSAEracer03
TRB0 GUY
FSAEracer03's Avatar
Special Tool... what AFM and injectors do you have on there?
Old 02-12-2005, 05:02 PM
951kid
951kid's Avatar
did you wrap your headers/cross over pipes with them intalled, or did you remove them to wrap em, i was thinking about doing it but if you need to remove the exaust i might not be able to do it myself
thanks
Anthony
Old 02-12-2005, 05:08 PM
special tool
FSA - I have 72 pound Siemens and a Vitesse MAF
Kid - you can do it without removing them, but it will take all day. Also, you will get better performance with the wrap, over the heat shields. (I have data )
and you cannot see if the headers are cracked with the factory heat shields in place. You will definitely not be able to remove the heat shields with them still bolted to the head, unless you are an INCREDIBLE badass mechanic.
Old 02-12-2005, 05:18 PM
schnellfahrer
schnellfahrer's Avatar
That's good news, L. I'm installing ST2 in a couple of weeks.
Should be interesting to see how the spool up is compared to ST3.
If you're seeing 15psi@3250, ST2 should boost 15psi before 3000.
Old 02-12-2005, 05:28 PM
NZ951
NZ951's Avatar
I would be surprised if you can boost 15psi before 3000 with a stock exhaust!
Old 02-12-2005, 05:35 PM
hosrom_951
hosrom_951's Avatar
He ordered a 3"-er
Old 02-12-2005, 05:36 PM
schnellfahrer
I agree, but I'm hoping that the 3" Lindsey exhaust sitting in a box right next to the Vitesse kit here in my livingroom will help.
schnellfahrer
My god, 'Sam is quick!
Old 02-12-2005, 05:42 PM
hosrom_951
hosrom_951's Avatar
Just one of the benifits of working from home and having an internet browser automatically refresh every 30 sec (need to for work reasons)
Old 02-12-2005, 05:46 PM
NZ951
NZ951's Avatar
Did you get a 3" downpipe as well Eivind?
Quick Reply: HOLY SH#@!&*@T Vitesse stage 3 spoolup
